Unable to Release Trunk - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By MacDaddy
post #1 of 9 (permalink) Old 04-05-2014, 11:24 AM Thread Starter
I am new to the Forum. We have a 1984 Alfa Romeo Spider Veloce. It was not manufactured to have a key open the trunk. We have tried the trunk release and it will not open, the cable is not broken, you can hear it click but does not open. Any suggestions?
Thank you,
Wanda
Wandak is offline
post #2 of 9 (permalink) Old 04-05-2014, 11:51 AM
John Gallagher's Avatar
If you search the forum, you'll find many solutions. All is not lost and you won't have to drill behind the license plate.
JBetc
85 Graduate
"They all do that."
John Gallagher is offline
post #3 of 9 (permalink) Old 04-05-2014, 11:54 AM
Better yet, just look above at the FAQ. : )
JBetc
85 Graduate
"They all do that."
post #4 of 9 (permalink) Old 04-05-2014, 02:47 PM Thread Starter
Thanks for the information we will try.
Wanda
Wandak is offline
post #5 of 9 (permalink) Old 04-06-2014, 07:57 AM
Alfajay's Avatar
Sorry, but that isn't clear. Are you saying:
- The lever won't move at all
- The lever moves, but the trunk lid doesn't pop up
If the lever won't move, perhaps it is locked (there should be a key slot towards the top of the lever.
If the lever moves, and it feels like it is pulling a cable, and you hear that click back where the latch is located, then try this: Have one person work the latch while the other pushes/pulls on the trunk lid. Try pushing it down and up while the latch is fully pulled.
Alfajay is offline
post #6 of 9 (permalink) Old 04-06-2014, 02:30 PM
I had a broken cable on my 'Spider, and was told you need to drill a hole in the rear behind the plate to pop the trunk,,,not true, there is a hole under the rear of the car...there is a posting here of a tool a friend of mine made to pop the trunk, than you can replace the cable...
themick is offline
post #7 of 9 (permalink) Old 07-01-2019, 09:43 AM
I can't seem to find the post or any pdf of the owner's manual online...my owner's manual is in the trunk. I bought the car and the trunk cable snapped the first time I tried it. now can't get into the trunk at all. Would sure like some help with the screwdriver trick before taking everything apart.
MacDaddy is offline
post #8 of 9 (permalink) Old 07-01-2019, 10:31 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Where did it snap? What is the screw driver trick?
You'll need to take everything apart to replace the cable.
https://www.alfabb.com/bb/forums/spi...way-latch.html
ossodiseppia is offline
post #9 of 9 (permalink) Old 07-21-2019, 03:49 PM
Thanks!
the cable turned out to be fine....as some suggested here it was the plastic lever that had failed. I tried to replace it with a chrome one from CenterLine as it is much stronger. Unfortunately, you can't use it unless you take the entire cable out and rethread which I think is impossible. So I exchanged it for the original plastic and all is well now. Thanks for the help!
sloboy89 likes this.
MacDaddy is offline
