1967 Duetto Timing Question - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 06-20-2006, 01:45 PM Thread Starter
Hello All,
Stupid question time. I am trying to check timing on a 1967 Duetto, 1.6 liter engine. There is supposed to be a fixed and advanced mark on the flywheel. I have not had luck finding two marks. There is a small notch in the flywheel which was marked by the PO in red, but I can not seem to find another. I'd like to check timing at 5,000 RPM. The red mark is showing up nicely at idle using a strobe. Any idea where the second mark should be ? Thanks.
Mark
quasi is offline
post #2 of 4 (permalink) Old 06-21-2006, 07:01 AM
Andrew's Avatar
There should be a P (TDC) and F (static timing) right next to each other. M (maximum timing) will be advanced from the F a ways. Sometimes if you clean the pulley with a solvent, then lightly polish with steel wool or emery paper, you can get the marks to show up better. And try shining a flashlight at an angle to where you think the marks are.
To find the P, turn the engine til #1 is at TDC (put a pencil or something in the spark plug hole and stop when the pencil reaches its highest point, then starts to fall). Look for the P and F marks right by the water pump pointer at that orientation.
Andrew
Andrew is online now
post #3 of 4 (permalink) Old 06-21-2006, 08:25 AM Thread Starter
Thanks Andrew,
Sometimes you just need someone to kick start you !!
Mark
quasi is offline
post #4 of 4 (permalink) Old 06-21-2006, 08:27 AM
My Alfa pet peeve
Andrew is right. There should be three marks. Once you clean the pulley, you can mark them with various colors to see them better, and possibly also paint the marker. Which brings me to my Alfa pet peeve. Only an Italian could put the timing marks on the opposite side of the engine from the distributor. Unless you have six foot long arms, you cannot move the distributor while watching the timing marks to set the timing!
(2) 1967 Duettos (currently being made into one decent driver)
1995 Nero & Tan 164Q as a second daily driver (at least in the summer) and 164LS repair project
99 Ford Taurus SHO (my daily driver, especially in the winter)
07 Jeep Grand Cherokee (Wife's DD and to haul the boat).
peglegtom is offline
