Motor Mount Problem - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By mcola
  • 1 Post By rcess
post #1 of 6 (permalink) Old 04-22-2013, 01:58 PM Thread Starter
AlanMoor's Avatar
Send a message via MSN to AlanMoor
Motor Mount Problem
1973 Spider w/ 1750 (not the original motor, obviously)
I replaced my motor mounts with new ones from IAP. Now my engine leans a bit to the left. I tried re-loosening the four bolts connecting the two mounts to the crossmember and man-handling over to the right a bit with no success. There doesn't seem to be a lot of room for adjustment, and removing the passenger's side was such a PITA that I don't want to go there again if I don't have to. I managed to replace it with both SPICA pump and starter in place.
Again, the motor lists to the left (driver's side) so that the driver's side cam cover is about 1/4 inch lower than the passenger side. It's very noticeable. Will this put undue stress on the transmission mount? Anybody else ever encounter this?
My thought at the moment is to shim the driver's side mount to level things out, but that seems a bit hillbilly, if you know what I mean. (No offense to hillbillies, I am one).
'73 Spider w/ '74 bumpers and 71(?) 1750 motor
AlanMoor is offline
post #2 of 6 (permalink) Old 04-22-2013, 02:01 PM
mcola's Avatar
That is normal. The top should lean to the driver side by 4-5 degrees. The oil pan will be level with the floor.
adowns likes this.
Mike
'87 Quadrifoglio
mcola is offline
post #3 of 6 (permalink) Old 04-22-2013, 02:02 PM
rcess's Avatar
The tilt to the left is normal. It is the bottom of the oil pan that should be level, not the cam cover.
adowns likes this.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
rcess is offline
post #4 of 6 (permalink) Old 04-22-2013, 02:10 PM Thread Starter
AlanMoor's Avatar
That makes sense in retrospect. When I was removing the passenger side mount, I had a heck of a time because the mount had "crushed" down onto the bottom mounting bolt. It was truly shot. Which probably made the engine lean to the right, so I was used to seeing a level cam cover. Now that it's correct, it looks odd to me.
Moving on to the transmission mount tonight, then.
AlanMoor is offline
post #5 of 6 (permalink) Old 09-21-2019, 05:29 PM
I was worried about my engine leaning to the left. This old thread assured me all is ok. Thank you mcola and rcess.
adowns is offline
post #6 of 6 (permalink) Old 09-22-2019, 03:39 AM
A better thread on Alfa engine tilt.
https://www.alfabb.com/bb/forums/eng...gine-cant.html
adowns is offline
