Lower Radiator Hose Replacement - Any tips? - Page 3 - Alfa Romeo Bulletin Board & Forums
 2Likes
post #31 of 36 (permalink) Old 04-11-2019, 06:47 AM
kevinl's Avatar
Originally Posted by Salsa903 View Post
Wow those hoses look nice! Thanks for the suggestion. I failed to mention I have a 1991 Spider with AC and it looks like they do not have a hose for that.
Call Dean at Trail Auto, he has the correct fitting hose
1993 Spider Veloce
2016 4c Coupe
1992 Spider Veloce (sold)
kevinl is offline
post #32 of 36 (permalink) Old 04-11-2019, 02:51 PM
pantera928's Avatar
1990 and newer spiders use a totally different hose. Putting a hose on a 1989 and older is a piece of cake compared to a 1990 and newer. I have 3 different hoses or better said, hoses from 3 different vendors and they all are too tight to go on the water pump end in my opinion.
As mentioned, hot water and lubricant should usually do the trick but that should not be the case. I call ******** on this one. Someone needs to make a hose that fits better on the water pump end.
Obviously this has been an issue for many years.
I am still running my old hose because i just haven't felt like trying to put a new one on again.
Vintre likes this.
pantera928 is online now
post #33 of 36 (permalink) Old 04-11-2019, 08:54 PM
Thanks Pantera928! After working on this again this evening I am wondering if I should take the AC compressor off? I finally got the hose over the lip of the water pump, but cant get it on enough to get a clamp on it. Has anyone used a heat gun and got this to work? Not sure if that is a good idea or not. Thanks for your responses.
Salsa903 is offline
post #34 of 36 (permalink) Old 04-12-2019, 07:31 AM
Vintre's Avatar
I used a heat gun to warm up the rubber as well as a bit of spit on the inside of the hose and the fitting to help it slip on.
Takes patience.
Good luck,
Vin
Vintre is offline
post #35 of 36 (permalink) Old 04-13-2019, 01:22 PM
Love the spit idea, maybe a spit-soap combo!!?? Spit will make the soap slippery-er without allowing it to run all-over and then also make the grip slippery!!! Now to go find some heavy mucus spit...maybe a lively bull dog??!! LOL
azALFAowl is offline
post #36 of 36 (permalink) Old 04-15-2019, 06:52 PM
Got a heat gun on it and went right on! Thanks all for your input.
Vintre likes this.
Salsa903 is offline
