!982 Spyder: Passenger Mirror - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 07-10-2011, 09:37 AM Thread Starter
Oh dear! My passenger side mirror broke off from the age and heat. Can this be saved?
If not how do I take this off?
Saman is offline
post #2 of 7 (permalink) Old 07-10-2011, 11:07 AM
alfaporsche's Avatar
I don't know if it can be saved- my experience with gluing plastic has not been great. However, I do know you can remove the mirror itself from the base- assuming it's the same as the later year S3s- and hopefully find a replacement. If you fold down the small triangular rubber flap on the near end in the photo (the one down at the base), you can use a metric allen wrench (I don't remember what size) to loosen the mirror from the base.
alfaporsche is online now
post #3 of 7 (permalink) Old 07-10-2011, 11:07 AM
86spider's Avatar
Remove the inner door panel, look up in there and you will see how it is attached. I think the only way you could save this would be in a box in the garage. Worthwhile as you may need the painted shell or movement mechanism later on.
good luck
86spider is offline
post #4 of 7 (permalink) Old 07-10-2011, 11:27 AM
post #5 of 7 (permalink) Old 07-10-2011, 12:29 PM
86spider's Avatar
I stand corrected, must be remembering a different car. I would still save the old one.
I will have to check mine if I ever get home again.
86spider is offline
post #6 of 7 (permalink) Old 07-10-2011, 02:34 PM Thread Starter
Removed.
Thanks guys. The rubber flap and the allen key did the trick. Looks like its snapped right off. Glue wont help. Have to try for a replacement somewhere.
Saman is offline
post #7 of 7 (permalink) Old 07-12-2011, 05:51 AM
azzura's Avatar
power mirror
i have very good red power passenger side used red mirror,
if your interested [email protected]
azzura is offline
