Starting problem - 86 Spider Veloce 2.0 - Page 4 - Alfa Romeo Bulletin Board & Forums
post #46 of 46 (permalink) Old 07-31-2017, 10:25 AM
BB Janitor
ghnl's Avatar
Welcome KW.
The best wire diagrams for our cars are made by BB member PapaJam. They are color coded and vastly superior to the cryptic Alfa versions. Send him a PM (Private Message), include your email address & specifics about your Alfa (model year, etc) and he'll send you some .pdf files that will make chasing Alfa electrons much easier. I had an office supply store print out color copies on 11" x 17" paper then plastic laminate them - perfect for shop use.
In the meanwhile I'd suggest replacing the fuses. They could be decades old by now. Your '86 should have the more reliable blade fuses but even so it can't hurt to replace them and eliminate that as a possible weak point.
Item I3 "acoustic warning" is the horn relay.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
