yet ANOTHER Alfa project - and I haven't my previous project yet! - Alfa Romeo Bulletin Board & Forums
post #1 of 46 (permalink) Old 09-27-2010, 09:00 AM Thread Starter
comancheflyer's Avatar
1969 roundtail. Body and paint looks great, engine department looks worse then terrible. I'm having a nasty itch to either go webers or what about sneaking in a later 2.0l out of a later 80's or 90's spider injection and all. Kind of a Alfa retromod? Anybody ever do this? I like the looks and sounds of the webers on my giulietta, but I also like the drive-ability of my 90 spider. mmmm
any thoughts on this matter?
60' PA-24 Comanche
61' Giulietta Spider
69' 1750 Boat tail
73' 911T
89' Milano Gold
90' Graduate Spider
comancheflyer is offline
post #2 of 46 (permalink) Old 09-27-2010, 01:08 PM
Don't be silly, that engine bay looks just fine from the looks of it. There's nothing obviously disconnected, the vapour separator top is still even together, and you even still have your rad cowl. The spica system is just fine! Why go to the bother of having to change out your wiring harness, adding etc. etc. when the original is just perfect.
Did you run it at all?
Marc
cotie1750 is offline
post #3 of 46 (permalink) Old 09-27-2010, 01:12 PM
gadwhite's Avatar
keep stock gets my vote
I think you'd lose a lot of value if you modernise this little beauty. Go stock all the way is my vote. Good luck
[B]1985 Spider Veloce (Isabella),[/B]
2015 Honda Accord Hybrid Touring
gadwhite is offline
post #4 of 46 (permalink) Old 09-27-2010, 01:47 PM
msiert's Avatar
My vote is to keep it stock....................looks great!!!
Darkside Member
msiert is offline
post #5 of 46 (permalink) Old 09-27-2010, 02:14 PM Thread Starter
you guys win - stock it is. Has not run in several years, so its time for a rebuild. linkage to the pump feels rough like something is bad inside. Guess I'll have to have Wes rebuild it more than likely. Pretty happy about the lack of rust, you never know what to expect when you put a new car up on the lift and have a look at the end trials.
60' PA-24 Comanche
69' 1750 Boat tail
73' 911T
89' Milano Gold
90' Graduate Spider
post #6 of 46 (permalink) Old 09-27-2010, 05:11 PM
Alfajay's Avatar
Well, just to be ornery, here's another suggestion...
My Duetto has a 2L with Webers. 'Course, mine is the earlier (1600) model, which did come with carbs from the factory (and had no engine when I got it). To me, Webers provide a dirt simple solution. Sure Spica is more elegant, sure Bosch EFI is more efficient, but... when properly setup Webers start, idle, and run great. No complicated wiring, no electronics, no high-pressure fuel system, and you wouldn't have to make any irreversible modifications. I do understand the "keep it original" sentiment, but figure that as long as the next owner can easily convert it back to stock, then I've done my duty.
If your '69 has a 1750, then the 2L wouldn't provide much of a displacement increase. And by sticking with the 1750 you'd avoid having to mate the 2L crank to a mechanical clutch, or convert the pedal to hydraulic. So, sticking with the 1750, but Weberizing it, could be another strategy, especially if the Spica pump needs an expensive overhaul.
'63 Guilia spider
Alfajay is online now
post #7 of 46 (permalink) Old 09-27-2010, 10:05 PM
Subtle's Avatar
Somewhat partial to the performance that one can get out of a strong 2 L in the earlier models.
Bob,
Subtle is online now
post #8 of 46 (permalink) Old 09-28-2010, 10:27 AM
Dickson's Avatar
Nice looking project! Good luck. Dickson
A.L.F.A
Dickson is offline
post #9 of 46 (permalink) Old 09-28-2010, 10:40 AM
A 69 should have a hydraulic clutch. A 2L is a drop in clutch/bellhousing portion. But I prefer the 1750. With Webers they are really nice. But it is getting expensive to convert to Webers, if you do it right.
hotlegs32 is online now
post #10 of 46 (permalink) Old 09-28-2010, 12:37 PM
Alfajay's Avatar
Oops, you're right. I had argued for keeping the 1750 to avoid the hydraulic clutch conversion, but hotlegs is right - not an issue.
Weber conversions can be expensive. But then comancheflyer mentioned that the Spica pump on his new toy needs attention, and that can be expensive too. To me, Spica has always been "black magic" - I dislike spending money on something I don't fully understand, I worry that I may spend $X, only to find that it'll take another $Z to make it work properly. With Webers, the budget is significant, true, but at least it is known from the outset.
'63 Guilia spider
post #11 of 46 (permalink) Old 09-28-2010, 02:15 PM
Use your 90 spider as a parts car and fit the engine tranny and rearend into the 69.. Also use the brakes. Convert to hanging pedals with booster.. then do the A/C system.. nice stereo and plush carpet and seats. You will then have a Motronic boatail.
If you could find a twin spark that would be even better. Make it a real retromod.
Pwr steering from a series 4 .. It could be a nice machine. You need Panasport wheels too. Fly Yellow paint. All the spider upgrades offered. Bushings .. springs.. shocks.. drilled rotors.. etc.
Stan Murray is offline
post #12 of 46 (permalink) Old 09-28-2010, 06:16 PM
msiert's Avatar
And I can see why............one hot ride you got there Bob.
I would vote for a 2L just for the avaibility of parts, the 1750 is getting to be a rare bird.
Darkside Member
msiert is offline
post #13 of 46 (permalink) Old 09-28-2010, 06:20 PM
gigem75's Avatar
I'm getting 30.9 when driving for mpg out of my HP pump Wes recently did and just as much power as Webers.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #14 of 46 (permalink) Old 10-12-2010, 08:57 AM Thread Starter
Roundtail resto update
Well, after getting it home, I discovered that it was invaded by that dreaded rust worm, mostly on the rear shelf area behind the seats. So ... the last week was spent gutting her of brake lines, fuel tank, fuel lines, well pretty much anything that wasn't welded in place. Next stop - Reids Auto Body for a 3 month make over. Stay tuned for body shop updates. Now - I have to decide on a color. Original was silver. Now its green. I'm heavily leaning towards rosa right now. Well, I still have time. Stay tuned ....
60' PA-24 Comanche
69' 1750 Boat tail
73' 911T
89' Milano Gold
90' Graduate Spider
post #15 of 46 (permalink) Old 11-19-2010, 07:33 AM
billh1963's Avatar
Any updates?
billh1963 is offline
