#3 Cyl. Spark Plug Fouling - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 06-07-2010, 05:22 AM Thread Starter
Can anyone suggest to me the cause of my #3 spark plug fouling on my fuel injected Spider? At an idle it runs rough. I get a noticable drop in rpms when I remove the wires from 1, 2, and 4, but non when I remove #3. At higher rpms it seems to run ok. I have replaced the plugs with hotter ones. It still fouls. Any suggestions???
charliepatten is offline
post #2 of 5 (permalink) Old 06-07-2010, 06:24 AM
BB Janitor
ghnl's Avatar
What model year Spider? If EFI it could be a faulty fuel injector (stuck open) or an intake air/vacuum leak (the extra air from a leak will cause the computer to compensate by squirting more fuel. If the leak affects other cylinders more than #3 then #3 ends up 'rich' because all the injectors squirt equally - the computer does not control them individually.)
If it is SPICA then I don't know much about that.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 5 (permalink) Old 06-07-2010, 11:36 AM
radamm's Avatar
I would start with a compression check. A weak cylinder can foul the plug with oil and, or fuel.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #4 of 5 (permalink) Old 06-07-2010, 11:48 AM
Farace's Avatar
I would start by testing the wire itself. I've had one wire from a set go bad. swap wires with another cylinder and see if the problem follows the wire or stays with the cylinder.
[FONT="Century Gothic"][B]Bob Farace[/B]
[COLOR="DarkGreen"]1971 Alfa Romeo 1750 Spider Veloce[/COLOR]
[I]Director, Connecticut branch, Scuderia Non Originale[/I][/FONT]
Farace is offline
post #5 of 5 (permalink) Old 06-07-2010, 02:20 PM
Roadtrip's Avatar
I think you have an electrical problem, not a fouling problem. New distributor cap, new wire, and new spark plug.
John Stewart
74 Spider
91 164S
Roadtrip is offline
