Pics of a Duetto racer buildup - Page 51 - Alfa Romeo Bulletin Board & Forums
 34Likes
post #751 of 764 (permalink) Old 11-11-2018, 04:05 PM Thread Starter
Nader's Avatar
Originally Posted by Alfar7 View Post
Nader, is that car Christian Sniady`s or Jon Norman by chance?
Car belongs to McKean. Pretty sure the engine is built by Jon Norman's shop. Fred S. (JustcallmeFred) maintains it, he knows for sure.
69 Spider, 2L, street; pursuit of happiness
69 Spider, 1.8L, race; happiness of pursuit
Nader is offline
post #752 of 764 (permalink) Old 11-25-2018, 08:08 PM Thread Starter
Nader's Avatar
Happy holidays.
Thinking about it, I've had two relatively minor recurring issues with the car.
One is the side dump exhaust with the megaphone cracking and falling off. I fixed that with beefier welds and better rubber mounting.
The other is failing alternators. I think I've mentioned it before. In one of my last races, the nut came off the alternator mounting bolt, and I lost the 10/12mm shouldered bolt. Must have been because of all the mounting and dismounting of failed alternators, and I probably under-torqued it last time. Anyway, by mid race, the alternator was hanging on by the tensioner. No alternator means no water pump. Discovered it when my radiator boiled over in a race and my temp needle got pegged. Luckily caught it before lasting damage was done. Luckily, @justcallmefred had a spare to loan me, and I was able to finish the weekend. Thanks again, Fred!
That bolt is a little tricky. It's 12mm through the engine bracket, then narrows down to 10mm for the alernator. And because of my setup with the mini alternator and oversized (underdrive) pulley, it can't be too long or it will grind against the pulley. I had to make one to replace the one I lost. If I'm going through the trouble to make a bolt, especially a big one, then by now you can guess how I'm going to it. Grade 5 titanium. If I'm making one, I might as well have two. Finally got around to doing it. Here's the process once again, starting with a couple of very nice longer-than-needed bolts, that needed to be shortened, then turned down and threaded on a lathe. Then finished by hand:
Nader is offline
post #753 of 764 (permalink) Old 11-25-2018, 08:18 PM Thread Starter
Nader's Avatar
Finished product beside the other bolt that still needs cutting+threading. Also showing the piece of 10mm allthread I used to limp the car on and off the trailer after giving Fred back his bolt. Realistically could have used this hack indefinitely. Oh, and here's a small example of Ti wool I'm collecting. I now have multiple grocery bags full of this stuff. Just can't bring myself to throw it out. And finally an uninteresting picture of the bolt in its oily home. Engine bay is always this ugly by the end of the race season. I'll clean it next Spring.
Nader is offline
post #754 of 764 (permalink) Old 11-25-2018, 10:00 PM
PSk
Maybe you should lock wire the bolt in so you never have this issue again. Just a thought ... and nice work
'71 1750 Series 2 GTV:
PSk is offline
post #755 of 764 (permalink) Old 11-26-2018, 09:49 AM Thread Starter
Nader's Avatar
Thanks, Pete. That's a good thought. My race bikes are extensively wire locked. But with cars, especially this situation, space is awfully tight for wire locking down there, especially from above. I always use anti-seize on all the titanium and stainless fasteners on my projects, but in this case, I'll probably just use blue thread-locker in addition to a locknut. Belt and suspenders setup. And since I know you're thinking it, there's not enough space under the nut end for a lock washer. And putting one under that beautifully flanged titanium bolt head would be barbaric.
Since I mentioned bikes, they'd get jealous if their pictures weren't included. Here's a front hub, locked down in wire. That's a titanium brake stay I made, go figure. And yes, there's a Gulf Blue race bike lurking in the background.
Nader is offline
post #756 of 764 (permalink) Old 11-26-2018, 01:47 PM
conedriver's Avatar
The stand-off brackets were for an earlier (crude) alternator installation but, as an alternative to safety wire, I still reverse the big bolt and double-nut it.
George Schweikle
Scuderia Non Originale
conedriver is online now
post #757 of 764 (permalink) Old 11-26-2018, 03:11 PM
PSk
Another simple option is to drill the bolt for a split pin to trap the nut. Yes it might work loose but it cannot come off, meaning the bolt will always be there and races finished and won.
PSk is offline
post #758 of 764 (permalink) Old 12-09-2018, 05:35 PM
mac mclaren
hi nader ,,new member here to the forum ...have enjoyed reading your posts over the last 5 days ,,,well done you are a very talented gentleman ,,have inspired me to get onto my projects again after a long lay off ,,,thank you for your dedication to detail ,,regards mac
mac mclaren is offline
post #759 of 764 (permalink) Old 12-10-2018, 09:08 AM Thread Starter
Nader's Avatar
Thanks, Mac! I appreciate that. I, too, use other people's projects as inspiration for me to forge ahead with my own. I'm glad mine was able to do that for you.
sbadaro likes this.
Nader is offline
post #760 of 764 (permalink) Old 12-10-2018, 09:43 AM
Subtle's Avatar
The Alfa BB helps with rationalizing your own project.
There is always someone else spending more!
Bob,
Subtle is offline
post #761 of 764 (permalink) Old 12-19-2018, 09:56 AM
2mAn's Avatar
Originally Posted by Nader View Post
Here's where I use some of that old Alcoa 6013-T4 aluminum sheet I bought from Boeing about 15 years ago when they still had their surplus available for sale to the public. I've mentioned before that I bought A LOT of Al sheet from them in varying grades and thicknesses without really knowing what I'd be doing with it all back then. This stuff is used on jet plane fuselage turbine cowling sheet metal.
Hey Nader!
Finally finished the thread. Slow days at work for the last few days has really helped. As expected, the thread was wonderful; it made me laugh, made my cry, made me proud... all the emotions! haha
If I can make one suggestion for a "someday" project, blocking off the openings that was done in this post (I dont think the pics came with the quote) left a nice opening on the insides for the radiator, but it leaves air a path to escape from and not head towards the radiator... path of least resistance ya know?... So my suggestion is to add some additional ducting/ shielding so that these openings direct all the air into and through the radiator. Probably want to add some mesh too just to prevent directing things other than air into the alooomineum radiator. Gotta protect the goods right?
-Simon
2mAn is online now
post #762 of 764 (permalink) Old 12-30-2018, 07:31 PM
2mAn's Avatar
Been watching a lot of vintage racing videos and look who popped up ...
About 14 minutes in...
Rollbar sure looks safe to me
-Simon
2mAn is online now
post #763 of 764 (permalink) Old 12-31-2018, 06:01 PM Thread Starter
Nader's Avatar
Thanks, Simon, for posting that. Keep in mind, I am in my little 1800cc 4 cylinder car doing my best to keep up with six cylinder 2.5L Porsches and Triumphs. The Bimmers are ridiculous, too.
Nader is offline
post #764 of 764 (permalink) Old 01-04-2019, 09:08 PM
2mAn's Avatar
I totally understand! Thereís a reason Iím building a Datsun Roadster and not a 2002, GTV, 510 or anything else to run in that B-Sedan group . Itís not just the displacement youíre battling but the guys with deep enough pockets to squeeze all the power out of the motors that only need to last a seasonsí worth of hours. Those guys are usually in B-Sedan. Iíll happily battle the Alfa Spiders and the assortment of British cars.
That particular gent has made some wise choices in his life as he campaigns a pair of 2002s, a CSL, a Chevron and I believe just picked up a E30 M3 too... sigh...
-Simon
2mAn is online now
