Pics of a Duetto racer buildup - Page 48 - Alfa Romeo Bulletin Board & Forums
 34Likes
post #706 of 764 (permalink) Old 06-07-2017, 07:18 AM
spider4me's Avatar
Sad to hear of Chuck's passing. I didn't know him but had seen him and his cars at other events. Thanks for sharing the details.
Neil
"Nominum quid geminus?"
spider4me is offline
post #707 of 764 (permalink) Old 08-14-2017, 10:11 PM Thread Starter
Nader's Avatar
Welp, it has been five years since my last trip out there, so I feel like it's time to go back out to Road America again. I feel like both myself and the car have developed significantly, so I hope to make a better showing this time around. I am signed up for the Elkhart Lake Vintage Festival on September 15 at Road America. I made several friends in the Alfa camp last time, and will be pitting with them again this year.
But first, I have to repair my cracked headers, again. My exhaust system hangs low, and it keeps banging against loading ramps and what-not while I am transporting the car. Those delicate, thin walled headers absorb the impact and inevitably crack. So I took them off, and re-welded them.
To fix the issue for good, I decided to redo my exhaust system from the headers back. I sliced up the collector so that I could introduce an S-bend so that it tucks up higher and closer to the body for more ground clearance. Then I ditched my old Magnaflow muffler for a smaller glass pack. Car was too quiet anyway with that muffler. Also trimmed up the megaphone and hung it up higher.
69 Spider, 2L, street; pursuit of happiness
69 Spider, 1.8L, race; happiness of pursuit
Nader is offline
post #708 of 764 (permalink) Old 08-14-2017, 10:14 PM Thread Starter
Nader's Avatar
Huh, I did that last post entirely by my phone using the mobile version of this website. Pictures came out like crap.
Nader is offline
post #709 of 764 (permalink) Old 08-15-2017, 12:00 AM
PSk
The problem with side exhausts is when they hit the body shell or ground it puts a lot of torque on to the exhaust manifold. Note how exhausts are usually designed to go down near the middle of the car, when rear wheel drive, so the engine, gearbox and exhaust all can move and twist together.
The only real solution, for side pipes, is to solid mount the engine and gearbox.
'71 1750 Series 2 GTV:
PSk is offline
post #710 of 764 (permalink) Old 08-15-2017, 12:10 AM Thread Starter
Nader's Avatar
Hi Pete. I had no intention of installing a side dump exhaust until I realized there was no room for traditional rear exit once the sliding block and its yoke was in place. I'm guessing Autodelta realized the same problem with the GTA.
Nader is offline
post #711 of 764 (permalink) Old 08-15-2017, 06:15 AM
Richard Jemison
Alfar7's Avatar
Exhaust
Nader, Jim Steck has tested collector lengths effect on HP/Tq.
Basically from the collector beginning the total collector length should be 15", 30", 45"or 60". Nothing "in-between" as loss is in 8HP range. Any muffler/resonator is considered the end of the collector. Out the rear exhaust likely causes resonance that will screw up mid-range AFR.
Just FYI
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #712 of 764 (permalink) Old 08-15-2017, 11:19 AM
PSk
Could you just dump the exhaust down to the ground, instead of the side pipe? I'm not sure if this would even be legal on a race track but my understanding is that it just has to exit past the driver?
Unfortunately I believe your exhaust will crack pretty quickly as it is so tight up against the body so there is no room for movement.
IDEA: Could you install some of that flexible exhaust pipe before it turns to go towards the side?
PSk is offline
post #713 of 764 (permalink) Old 08-15-2017, 03:20 PM Thread Starter
Nader's Avatar
Just FYI
Thanks for the tip, Richard, but I think I stumbled into the magic of harmonics by accident. 15" you say?...
Nader is offline
post #714 of 764 (permalink) Old 08-15-2017, 03:31 PM Thread Starter
Nader's Avatar
Thanks for giving this so much thought, Pete. The exhaust has at least one centimeter clearance from all rails and panels, you just can't tell from the photo. It is suspended by a double-layered rubber damped exhaust hanger. I can get away with that because this exhaust system is so light. The glass pack is only 5 pounds (previous muffler was 10 pounds). I do, however, need to damp the end of the megaphone like I did before. I thought I could get away without it this time now that the megaphone is shorter, but there is still excessive vibration at the end of it.
I only started banging the exhaust and cracking the manifold when I switched to 55 series tires, which lowered the car those last few crucial millimeters of clearance that I had before with the 60 series tires.
Nader is offline
post #715 of 764 (permalink) Old 09-13-2017, 02:47 AM Thread Starter
Nader's Avatar
Put new shoes on the wheels. Street Spider in the background, as usual, looks on jealously. That car is a real sweetheart, really deserves it's own thread someday. A keen eye will spot the Road America track map on my truck's tailgate.
Nader is offline
post #716 of 764 (permalink) Old 09-13-2017, 02:58 AM Thread Starter
Nader's Avatar
I'm partway on the long journey to Road America in Wisconsin. I wanted to get a picture of the sign for the continental divide, but I was passing through in the dark.
And here's a picture at a rest stop somewhere between Bozeman and Billings Montana. Oh, and here's a picture of my set up at my favorite roadside campsite. This one is in Sioux Springs South Dakota, just before entering Minnesota. My second night on the road. First night was spent somewhere in the middle of Montana. Also at Walmart. Sleeping in the back of your truck every night on a 3 day road trip to race on the other side of the country is something every amateur racer should experience. Not really.
ossodiseppia likes this.
Nader is offline
post #717 of 764 (permalink) Old 09-13-2017, 11:00 AM
PSk
Heck that's dedication!
GioGTVTS likes this.
PSk is offline
post #718 of 764 (permalink) Old 09-13-2017, 07:12 PM Thread Starter
Nader's Avatar
Yes, Pete. I am not messing around! My first trip to Road America exactly five years ago was fun, but I was unprepared. To liken it to visiting another country, I feel like this time, I have studied the culture and I know the language. I hope this trip and race will be more fulfilling.
Here I am, somewhere in Minnesota. More greenery, and farm implements.
Nader is offline
post #719 of 764 (permalink) Old 09-13-2017, 07:18 PM Thread Starter
Nader's Avatar
And here I am in Wisconsin. Home of Road America. I could've stopped here, but i'm continuing on down south to Chicago to hook up with my college buddy. He is also racing, a series 2 Spider, and we will caravan back up north to the track.
I know there is no Alfa content in these pictures. Perhaps it is more of an ode to my truck and trailer which gets me there.
Nader is offline
post #720 of 764 (permalink) Old 09-14-2017, 01:07 AM
spydaman's Avatar
That's OK mate we all know what's in the trailer no pics needed for that .Maybe a couple after the race.
Current cars 1975 spyder under resto, 1973 Berlina Resto 1976 Berlina parts car 1972 GTjunior fully restored, 1 complete rolling shell spyder.exit 1989 75 T/S sold
spydaman is offline
