Wet engine now horn & lights don't work!!??? - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 05-25-2009, 01:03 PM Thread Starter
Need4speed's Avatar
I just spray washed/hosed my radiator and front engine and my horns (ONLY, who knows what else) do not work!! Obviously a fuse or relay, but both?? And which horn/fuse?
Thanks!
1991 Alfa Spider, 1980 MGB LE, Triumph Spitfire, Miata,
"I feel the need!"
Need4speed is offline
post #2 of 6 (permalink) Old 05-25-2009, 01:21 PM
1966-2013
Tifosi's Avatar
Or mabe not a fuse or relay (headlights aren't on relays unless you converted them and the horn relay is in the fusebox inside the cabin) but just stuff still wet and making continuity or circut issues.
Darren
as hosted by
Tifosi is offline
post #3 of 6 (permalink) Old 05-25-2009, 01:58 PM
alfafan61's Avatar
Wait a day for the water to evaporate and all will be fine. The electical connections in the egine bay for the most part are not sealed so most likely you have a wet short.
Alfafan61
(79 Spider - Pauline)
(1995 164 LS - Virginia)
alfafan61 is offline
post #4 of 6 (permalink) Old 05-25-2009, 03:44 PM
Gary Williams's Avatar
Originally Posted by alfafan61 View Post
Wait a day for the water to evaporate ... most likely you have a wet short.
Wet shorts? I thought we were talking electrical system.
Gary Williams
Many Alfas. All gone, but none forgotten
Gary Williams is offline
post #5 of 6 (permalink) Old 05-25-2009, 05:49 PM
When you find out the problem, pleeeeeeeease send me a PM with the culprit, as I have a similar problem, maybe worse. Good luck.
Joe
Joe Papa Sr is offline
post #6 of 6 (permalink) Old 05-25-2009, 06:54 PM
Been there, done that...
Power washed under the wheel wells, radiator of my 1986 Spider, had lots of weird lighting problems. Removed all the bulbs and blew out connectors with compressed air. Make sure to install bulbs correctly-that is don't mash copper connectors causing a short as I did.
Duke58 is offline
