-   Spider - 105 & 115 Series (1966-1994) (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/)
-   -   #1 spark plug fouling (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/151594-1-spark-plug-fouling.html)
Duke58 05-25-2009 09:54 AM
...and only the #1 spark plug fouling on the intake side, 1986 Spider.
Using NGK plugs. I'm thinking that the injector is bad?
Any tips appreciated...
Duke
msiert 05-25-2009 10:02 AM
Could be the piston rings or the valve guildes are bad on that cylinder? Do a compression test to see if that cylinder is low compared to the rest.
Duke58 05-25-2009 10:10 AM
Will do!
Thanks, Murray!
Recalling from past tests- the #1 cylinder was more than 15% lower than the remaining three.
Might be time for a valve job...and motor mounts again. At least the VVT mount still works.
Duke
msiert 05-25-2009 10:24 AM
Originally Posted by Duke58 (Post 751596)
Will do!
Thanks, Murray!
Duke
The question would be is it the valve guides or the piston rings that's what you have to determine. With carbs or ITB's you have to throw in an additonal question "are the throttle bodys balanced out correctly"
Gary Williams 05-25-2009 10:42 AM
Did you check the ignition wire to the plug that's fouling?
Duke58 05-25-2009 10:48 AM
Gary,
No, but I will. Makes sense.
Last year, the #1 exhaust cam lobe and follower were galled- I replaced both and started using Rotella engine oil. So far, its all good.
I appreciate the advice!
Duke
Gary Williams 05-25-2009 11:50 AM
I like to start with the easy stuff and hope for the best. In this case, hope your plug problem is something simple: bad wire, faulty spark plug, dirt fouled injector. If the plug is fouled by a leaking valve guide or worn rings, you may get away with changing to one step hotter plugs.
Elio Comello 05-25-2009 01:02 PM
Hi Duke,
One other thing to check:
When I did my injectors, Cruzin found one that had a "fail" spray pattern. I could actually see a pile of buildup when looking in the injector port into the intake of the valve. I sprayed it with carb cleaner and used a test tube type brush to clean out the intake thru the injector hole.
If you do this you could also check the small rubber injector seal. Be careful not to lose the hard phenolic seal/seat in the intake manifold, if you use the spiral brush.
Sending the injectors in would be a wise thing...cheap at $16 each (including the upper and lower seals as well as new inlet screen and new pintle cap).
Best regards, Elio
Duke58 05-25-2009 03:48 PM
Thanks to all for your replies!
I'm removing the injectors after checking the spark plug wire and ensuring its good.
It was time for some maintenance anyway!
Duke
