Has any one had a problem with the snap ring in a drive shaft support? - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 05-12-2009, 04:10 PM Thread Starter
I just got a new drive shaft support from IAP and the channel that holds the snap ring is very shallow compared to the one that came off the car, in other words the snap ring rides high in the channel compared to the old one where the snap ring in half way down in the grove? any suggestions?....87 spider
thanks
chewys spider is offline
post #2 of 5 (permalink) Old 05-12-2009, 04:54 PM
Does it have any retention properties? You can also green locktight it as well. That should hold iot, ask iap if by chance there is a machining fault. Good luck
otteud is offline
post #3 of 5 (permalink) Old 05-13-2009, 09:12 AM
Hi Did you buy the snap ring from IAP too? Jim
Now....93 164s, 91 164s, 91 164L, 79 spider, '31 Ford model A Rat Rod, 88 Milano 3.0, 87 testarossa, 05 SL600 twin turbo V-12, 82 GTV6-3.0, Dodge Ram
alfaman1963 is offline
post #4 of 5 (permalink) Old 05-13-2009, 11:00 AM Thread Starter
no they did not have one in stock but said the factory one would work but it didn't so i went down to my local Caterpillar dealer......every body has one of those in town right? well they found one that worked great! the part number for any one that is interested is 6L-8797
thanks for all you help
Kurt
post #5 of 5 (permalink) Old 05-13-2009, 11:30 AM
ring
Thanks for the info... I asked you that because the IAP ring never worked for me ..... Thanks Jim
