Radio Removal - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 07-02-2005, 07:33 PM Thread Starter
Radio Removal
I have a 1988 Veloce. On a previous post it was said the radio could be removed by inserting a long thin rod into the holes at the four corners of the radio and the radio would pull out. I have tried this several times with no success. Do you have to fashion a tool to push in the holes simultaneously or what am I missing ? I have tried to pull the radio out and am afraid of breaking something if I pull any harder.
Thanks - Terry
Terry is offline
post #2 of 10 (permalink) Old 07-02-2005, 09:33 PM
Gubi's Avatar
Yes, you need to push something into all four holes simultaneously.
The official tool is available at Crutchfield:
http://www.crutchfield.com/S-I0bcyzU...earch=din+tool
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #3 of 10 (permalink) Old 07-03-2005, 01:48 PM Thread Starter
Thanks for the info on the tool. I fashioned a tool from a coat hanger but still no luck. I'm sure it is going in all the way but the radio will not come loose. Any other advice ?
Thanks - Terry
Terry is offline
post #4 of 10 (permalink) Old 07-03-2005, 02:58 PM
Supporting Vendor
JoeCab's Avatar
Terry and Gubi,
The tool for pulling the Alfa radios of that era is similar, but not the same as the universal DIN tool sold by Crutchfield, etc. The Alfa tool (on top in the photo) seems to hold the head unit much tighter than the universal tool.
Remember, these radios are "pull-out" decks, meaning the whole deck was designed to be pulled out of the car and taken with you to prevent theft. If they haven't been removed in a while, they can be stuck pretty good. The Alfa pullers also functioned as a carrying handle.
Once you pull the deck out, there is still a standard DIN sized frame you'll need to remove by bending the tabs down, and then you can unplug the wiring from the back of this frame and install your new deck.
Joe
JoeCab is offline
post #5 of 10 (permalink) Old 07-03-2005, 03:22 PM
Gubi's Avatar
Fair enough, Joe, but I can tell you I've got that exact same radio in my '87 Milano and it comes out easily with a pair of bent wire hangers. A set of appropriately sized wood nails always worked for my Spider (you only need to instert something about 1-2" to get it to release).
I know the Milano came with the "pull out take with you" deck, where the radio slots into a plug on the mounting frame. My S4 Spider came with a traditional radio where you need to manually pull the plug out of the back. I'm not sure which version the '87 Spider came with, but both versions seem to remove pretty much the same for me.
1974 GTV
1991 Spider
Gubi is online now
post #6 of 10 (permalink) Old 07-03-2005, 08:25 PM Thread Starter
Thanks for the info and pictures Joe. Are the ends of the Alfa tool flat ? I found the tools pictured at the bottom at a local parts store. I bought them but they are not working either. Right now I'm trying to get the radio out so I can see of the inline fuse is blown. The radio will not come on. It worked fine when I put the car away for the winter. If anyone has had a similar problem with the stuck radio let me know how you resloved it.
Thanks - Terry
Terry is offline
post #7 of 10 (permalink) Old 07-03-2005, 09:02 PM
Supporting Vendor
JoeCab's Avatar
I think your problem is not a blow fuse rather that the radio needs to have its security code input.
These radios have a 4 digit security code that needs to be entered whenever they are disconnected from electricity. If you're lucky it is written in the owner's manual or with some of your other records.
Joe
JoeCab is offline
post #8 of 10 (permalink) Old 07-04-2005, 03:42 AM Thread Starter
When I took the car out of storage I input the security code and had intermittent power then nothing. I'd like to install a CD player and power antennae so I'm back to getting the radio out. Are the ends of the Alfa tool flat ? Again, any suggestions from anyone on how to get this thing out.
Thanks - Terry
Terry is offline
post #9 of 10 (permalink) Old 07-30-2005, 03:48 PM Thread Starter
Can anyone help with this? I've tried the universal DIN tool and no luck. What is the difference in the Alfa tool ? Are they avaialble ? Getting frustrated, no music!
Thanks - Terry
Terry is offline
post #10 of 10 (permalink) Old 07-31-2005, 06:41 AM
GTD
GTD's Avatar
Terry
PM or e-mail me with your address. I'll send you the tool. Most any used car lot/garage would have a selection of these. The ***/FORD/others cars of the 80's all used them.
I suspect your problem is the tabs have been bent or distorted to the point that the tool isn't fully releasing them. Your welcome to try though!
Alfa Sapiens
GTD is offline
