S3 heater fan R/R & drain holes - Page 3 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #31 of 36 (permalink) Old 04-15-2019, 03:20 PM
kbartosiak's Avatar
Originally Posted by spiderserie4 View Post
you should be able to bypass the heater by joining a length of hose from the small waterpump outlet to the heater hose connection on top of the plenum. (tie the original WP hose out of the way, safe)
thats what I did when my heater dumped hot coolant on my feet whilst out on a drive
I carry a 4 ft length of heater hose now in the trunk!
Thanks for the tip! I need some more specific directions though - you mean inside the bonnet, between the engine and firewall?
Or just connect the tubes from left and right side of the heater, inside the car?
Spider 2.0 - 1985
159 1.9 JTDM - 2009
kbartosiak is offline
post #32 of 36 (permalink) Old 04-15-2019, 05:18 PM
The 4 ft of heater hose would be used to bypass the heater (core).
930cabman is offline
post #33 of 36 (permalink) Old 04-16-2019, 01:34 AM
spiderserie4's Avatar
this is how I did it on my S4. Dont make it so short that it kinks (hence the 4 foot length, maybe 3 ft. would do it too)
(Photo is an S3, just for illustration purposes..a rhd conversion by the looks of things)
ghnl and kbartosiak like this.
spiderserie4 is offline
post #34 of 36 (permalink) Old 04-19-2019, 12:54 AM
kbartosiak's Avatar
Done. I removed entire heater. I didn't removed dash. First I removed valve from the left (driver) side, which helped with top screws. So proud of myself!
My unit already has small hole in the bottom - no need for drill However, as I have no AC, I wonder what that's for? Especially if it's just a hole, water would be dripping to the carpet.
I took the unit to the local garage, they said it's tight, not leaking. I think that maybe it was just clogged with oil and stuff - I had a serious leaking problems with engine, repaired last winter.
Few pictures attached.
As I am not sure if I will be able to connect everything right (heater, central console wires, etc.) I'd be obliged for any photos how it should look like I took a few pictures myself, but I'm afraid not enough
Spider 2.0 - 1985
159 1.9 JTDM - 2009
post #35 of 36 (permalink) Old 04-24-2019, 12:25 PM
@kbartosiak That looks like an awful lot of crud in your heater box. Are your cowl drains clogged? I would check and fix that now! While it is apart, I would check the operation of the cabin fan. Usually you can easily remove it from the lower case half and inspect the brushes and lube the bearings. Then, test for proper operation using jumper wires to a 12v power source. Lots of other Maintenance and Repair that can be done more easily with the console and h-box removed. Have fun!
ALFA ANDY
andylarry is offline
post #36 of 36 (permalink) Old 04-25-2019, 05:03 AM
kbartosiak's Avatar
Drains cleaned, motor working.
Right now working on reconnecting the wires - e.g. grounding was connected instead one of the fan speeds, and (after my work ) indicator worked only with doors open
Should be back on the road later today though
andylarry likes this.
Spider 2.0 - 1985
159 1.9 JTDM - 2009
