Bosch L-Jet Spider R&R - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 03-08-2005, 09:08 PM Thread Starter
dwc
Bosch L-Jet Spider Starter R&R
Hi Group:
Any way the starter on my '87 Spider will come out without my pulling the intake plenum? Maybe I can pull the distributor and slide it past there? (BTW, this is the small, reduction-gear starter) An easy 20 minute job on my '74 looks pretty bad on my '87, so any time-savers would be appreciated. TIA.
Regards,
Dean
Lutz, FL
'74 & '87 Spider Veloce's
dwc is offline
post #2 of 4 (permalink) Old 03-10-2005, 05:52 PM
Stevew's Avatar
Location: Carson City, NV Class Champion Reno SCCA 2018
Starter Removal
Hello Dean:
Look's like no one on the BB has ever had to deal with pulling a starter and although I haven't either, here's a bit of information from PO records and my manual: In 3/96 the starter ($280) on my '87 QV was r&r with a one (1) hour labor charge. The only reference to starter removal comes from the Engine Overhaul Manual and is the first step in pulling the engine w/o the xmission. "Remove 3 bolts, slide starter out the front, remove shim". Maybe the writer feels if you're competent enough to get the starter disconnected, "sliding it out" is the easy part. Hey, what's the worse thing that can happen?
Good Luck!
Steve Waclo Carson City, NV; '87 Spider QV, ES Champion, 2018 Reno SCCA (125k);'93 Honda Nighthawk 750 (105k);'03 GMC Sierra SLE 2500HD Turbo Diesel (155k);'08 Altima Coupe 3.5SE, 6sp (125k)
Stevew is offline
post #3 of 4 (permalink) Old 03-12-2005, 09:50 AM Thread Starter
dwc
Hi Steve:
Considering all that's in the way, in terms of the Bosch fuel injection, I'm sure the starter R&R isn't quite so simple (although it is that simple on my Spica Spider), but I've heard from others on the Alfa Digest that the job isn't quite the terror I expected. I've also got to replace a leaky slave cylinder, and will likely be able to kill both jobs at once, from underneath the car.
I'll bet more than a few guys in the BB have done the starter job before, but I negelected to put "starter" in the title of my post, which I've just fixed. Thanks for your reply.
Regards,
Dean
dwc is offline
post #4 of 4 (permalink) Old 03-12-2005, 10:23 AM
MrT
MrT's Avatar
Changing the title after thread creation doesn't do much. I don't know how to alter it after the fact.
MrT is offline
