Hoop Rotisserie - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 2 Post By gprocket
post #1 of 1 (permalink) Old 07-19-2019, 08:02 PM Thread Starter
Hoop Rotisserie
I periodically get requests for drawings of our hoop Rotisserie. I lost my original files but finally got around to measuring the hoops. I didn't have a chance to measure the Vertical bars but you'll need make a plate to tie in the front frame where the steering box/idler arm bolt in. In the rear, you'll need to make some cross bars that tie in from the where the trunion bolts and the trailing arm points. If I get some time I will measure these as well but really you'll probably want to cut to size.
The base is optional. Sandwich dolly wheels between some square tube. We bolted them to a wooden frame and mounted pneumatic wheels to transport. Frankly I'm not crazy about the setup (seems unstable) but my guys love it and we've never had an issue...
The hoops fit Spiders and GTVs. I haven't measured for Supers but it would be easy enough to do so if someone needs to know.
Craig_m67 and Austin Alfa like this.
gprocket is offline
