CRC Freeze-Off - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 04-17-2019, 05:47 AM Thread Starter
divotandtralee's Avatar
CRC Freeze-Off
anyone used this "miracle-in-a-bottle"? I'm a devotee of PB and Acetone/ATF brew.
divotandtralee is offline
post #2 of 6 (permalink) Old 04-17-2019, 04:36 PM
Yes, it worked great on a rusted/frozen seat track screw in my Spider. Highly recommended.
See https://www.alfabb.com/bb/forums/spi...oto-guide.html
1974 Spider
Work gets in the way of my hobbies. Nothing takes just 5 minutes.
BobG is offline
post #3 of 6 (permalink) Old 04-17-2019, 07:02 PM
John Kouris's Avatar
Send a message via Skype™ to John Kouris
Great for remove sound deadner
John Kouris is online now
post #4 of 6 (permalink) Old 04-17-2019, 07:26 PM
Gordon Raymond's Avatar
It actually does work. I use a bunch of the "Gotta get that stuck thing LOOSE!" brews, sometimes with what I call a "cool" torch. Cool is not too much oxy in the oxy-acetylene or propane, not map-gas. Too hot and the penetrant burns off before penetrating, a little heat aids penetration. Then freeze-off is the 2nd phase in the "crack it loose" trick.
Gordon Raymond
Now:
Gordon Raymond is offline
post #5 of 6 (permalink) Old 04-18-2019, 05:58 AM
slowcreek's Avatar
I told you about that stuff......when working on the John Deere tractor. Good stuff, ain't it?
It's Giuseppe's giubos, not Guido's guibos, on my 78 Alfas
slowcreek is offline
post #6 of 6 (permalink) Old 04-18-2019, 07:30 AM
There are a lot of "free'emup" solutions, much depending on the specific issue. After you wrench twist long enough, you find out what works best and where.
YES, Pete did suggest this one which is better/easier than the liquid nitrogen I used in the past. I still have some of the canned nitrogen which came to me from a customer in G.B. Couldn't buy it here. Freeze Off IS available, and works just as well.
Gordon Raymond
Now:
Similar Threads
Which anti freeze? Gonzalo Molla Engine Repair, Diagnostics & Rebuilding 14 02-12-2017 05:50 PM
Destructive Anti Freeze f4driver GT (1963-1977) 11 11-08-2013 04:16 AM
Oil in Anti Freeze bahniuk Spider - 105 & 115 Series (1966-1994) 8 09-02-2009 11:19 AM
Has anyone use CRC 80W90API/GL-5 NEW GENERATION LIMITED SLIP GEAR OIL? alan dluzen Spider - 105 & 115 Series (1966-1994) 2 03-09-2009 09:17 AM
Alfa Night @ Jersey Freeze in Freehold, NJ rbitzer Car Events 2 08-16-2004 06:16 AM
