Differential Pinion Nut Tool Drawing - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Little Italian
post #1 of 5 (permalink) Old 01-25-2019, 01:22 PM Thread Starter
Little Italian's Avatar
Cold weather keeps me in-doors in the Winter so I like to sit around on the PC's, Work on my Electronics Projects and Draw. I had the fortune to be able to borrow the 1600 -1750 Differential Nut tool from Steve Swartz this summer so I took the opportunity to measure it up. Here is a pdf of the Autocad drawing for any body who wants to make one or have a good one made by a local machine shop. I don't know if Steve's wrench was of tempered or hardened material but the prongs on this tool needs to be able to torque up to a good one hundred-fifty ft/lbs. There's always one out there that is over tightened. The Alfa Spec on that big pinion nut is 58 to 101 ft/lbs. Good luck!
Milanoguy likes this.
......... Bud Feigel ........<Oo \*/ oO>....... Lexington, Kentucky ........
'82 RED GTV6 / 2.5 - '86 WHITE Spider Veloce 2000 - '71 GREEN GTV 1750
Last edited by Little Italian; 01-26-2019 at 03:15 PM. Reason: Having trouble getting the bitmaps or jpegs to load because of size. trying to add more attachments
Little Italian is offline
post #2 of 5 (permalink) Old 01-25-2019, 10:05 PM
hi
I cant see an attachments
cheers ian
62 LANCIA FLAMINIA GT 2500 PROJECT (now sold) 64 SPRINT GT (Gone)
68 1750 ROUND TAIL SPIDER 70 1750 GTV 62 101 GIULIA SPRINT
ITALCAROZ is offline
post #3 of 5 (permalink) Old 07-19-2019, 03:07 PM
86spider's Avatar
logged in?
86spider is offline
post #4 of 5 (permalink) Old 07-19-2019, 06:01 PM
coopp's Avatar
i had to switch to Classic mode of the forum to see the image.
coopp
'82 Spider
coopp is offline
post #5 of 5 (permalink) Old 07-19-2019, 07:30 PM
Hi Little Italian,
I have an 'original factory tool' that I've had it's critical dimensions replicated onto an impact socket. Find my post in the for sale section.
Looking at your drawing, you have either replicated the basic flaws found on the tool that you got from Steve Swartz or you have introduced them your self.
I would politely advise you to review your drawing as it does not match the original factory tool.
Regards Steve
Steve105 is offline
