Clutch fluid - Alfa Romeo Bulletin Board & Forums
 7Likes
  • 2 Post By Oldmencoolcars
  • 1 Post By Gubi
  • 1 Post By Oldmencoolcars
  • 2 Post By Gubi
  • 1 Post By AlfaDuc
post #1 of 6 (permalink) Old 08-13-2017, 01:14 PM Thread Starter
Clutch fluid
Just got my 1988 Alfa at the beginning of the summer, today the clutch started acting up and grinding and difficult to get in first and reverse. Pressure ,feel of clutch gone soft. I checked the reservoir and it is empty (hoping just a fluid issue) How much fluid should it take to fill it and what fluid would you recommend? doug
Stevebay22 and jhssrel like this.
Oldmencoolcars is offline
post #2 of 6 (permalink) Old 08-13-2017, 01:53 PM
Gubi's Avatar
It just uses DOT 4 brake fluid. But you've got a leak somewhere that you need to find and fix: either the master cylinder or the slave.
Stevebay22 likes this.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #3 of 6 (permalink) Old 08-13-2017, 03:00 PM Thread Starter
Thanks. Doug
post #4 of 6 (permalink) Old 08-13-2017, 03:22 PM
Gubi's Avatar
Quick test: fill the reservoir, then jiggle the pedal (just a bit in and out) quickly for a while. Depending how low the fluid level has dropped you can usually get the pedal back this way.
Then pump the pedal a while and see where it's dripping. If you didn't see liquid around the MC in the engine bay, however, it's most likely just a bad slave.
ghnl and Stevebay22 like this.
1974 GTV
1991 Spider
Gubi is online now
post #5 of 6 (permalink) Old 08-15-2017, 07:42 AM
I had the same problem years ago with my '88 Milano, and had to rebuild the clutch master cylinder. If you need to do the same, be warned that getting the master out and reinstalling it will be memorable.
62 Giulia Sprint
65 Giulia Spider Veloces (two)
88 Milano 3.0 L
91 Ducati 900 S/S
06 Ducati Paul Smart 1000
AlfaDuc is offline
post #6 of 6 (permalink) Old 12-07-2018, 01:42 PM
Red face Thank You
Just wanted to say thank you to the OP and the rest of you on this thread. Saved me from having to tow my 86 Spider 50 miles. Just needed some more fluid, now I can drive it down to the shop to get the leak fixed
Stevebay22 is offline
