Pinion & Diff Tools - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 2 Post By GregSef
  • 1 Post By GregSef
post #1 of 13 (permalink) Old 09-27-2016, 07:04 PM Thread Starter
GregSef's Avatar
Pinion & Diff Tools & setup
I've been trying to buy the Pinion depth setting tools and other transaxle tools for a little while with no success. Rob S. was kind enough to share some drawings of tools with me and the manuals give the dimension of the setting gages. So here they are, when I get a drawing of the pinion backlash tool I'll make that too. I would have rather bought these but I'm assembling a transaxle from some orphan parts and couldn't wait.
C.6.0164
A.4.0136 Indicator stand
I combined C.6.0163 & C.6.0193 length setting tools into one tool
The indicator pictured is to big to use. Part #80740764
from MSC fits into the diff well and is about $36.
Greg
Milanoguy and racingswim2006 like this.
1972 Berlina Vintage Racer, 1987 Milano Platinum (LeMons Car), 1982 GTV6 EP Race Car, 1974 GTV Vintage Race Car, 2012 VW GTI stage II, 1966 Corvette Coupe 327-350, 2007 Triumph T100 Bonneville. Dearly departed: 1971 Fiat 124 Spider, 1983 Saab 900 Turbo, 2004 Saab 9-3 Aero, 1995 BMW 540i Sport, 2014 Audi A4 (swamped)
GregSef is offline
post #2 of 13 (permalink) Old 09-28-2016, 06:49 AM Thread Starter
GregSef's Avatar
I'm still looking for the pinion backlash and preload tools if anyone has them to sell. If not then if you have a set I could borrow them, measure and create drawings. I will make them then.
Greg
GregSef is offline
post #3 of 13 (permalink) Old 09-30-2016, 07:37 AM Thread Starter
GregSef's Avatar
Pinion height tool in action. Looks like I need a thicker shim.
Greg
racingswim2006 likes this.
GregSef is offline
post #4 of 13 (permalink) Old 10-03-2016, 06:02 AM Thread Starter
GregSef's Avatar
I think maybe this should be moved to the driveline - transmission thread.
Gear pattern on my Verde transaxle. When I set the pinion depth to the distance that was engraved on it I got what I think is a great pattern. Setting it to the value I measured when removing it left with a poor pattern.
It does have a pretty big contact area compared to what I see in the handbooks etc. Next comes backlash to make sure its not to tight.
First 2 pictures are the pinion set to the factory markings next 2 are set to what I measured. I'm going with Giuseppe's setting from the factory.
The LSD is setup as RJ recommended, 1 extra friction plate per side and no preload.
Greg
GregSef is offline
post #5 of 13 (permalink) Old 10-04-2016, 02:48 PM Thread Starter
GregSef's Avatar
Sunex makes a 30mm crow foot and a 1/2" drive 36mm deep well socket that handle the input shaft and pinion shaft nuts. There about $11 each on eBay.
Sunex 236zmd 1/2-Inch Drive 36-Mm 12-Point Deep Impact Socket | eBay
The link doesn't seem to work so just search for that part number on eBay.
Also a 7/16" 8 point socket seems to work on the square heads of the shift detent bolts. If they are stripped you can hammer on a 3/8" 8 point. Those sockets are about $6
Greg
GregSef is offline
post #6 of 13 (permalink) Old 10-05-2016, 11:45 AM Thread Starter
GregSef's Avatar
Necessity is the mother of invention. I didn't have the factory tools to measure the ring & pinion backlash. So I made up a piece that jams into the diff carrier. You can not use an 1/2 shaft axle stub because it can move independently. Backlash is .005", so its right where it should be.
Also measured the diff carrier preload. It looks like 15 inch / pounds which is near the top of the spec for new differential bearings. So I think I'm good.
Greg
GregSef is offline
post #7 of 13 (permalink) Old 10-06-2016, 05:59 AM
kredden's Avatar
Nice job Greg!
Kevin
Milano registry custodian(
kredden is offline
post #8 of 13 (permalink) Old 10-06-2016, 09:00 AM Thread Starter
GregSef's Avatar
Originally Posted by kredden View Post
Nice job Greg!
Kevin
Thanks Kevin, Like a lot of things Alfa- I never really wanted to get in this deep but here I am.
I modified the Ring & Pinion backlash tool to be able to measure the Differential carrier preload by putting a bolt into it. Then i use a inch pound indicating torque wrench to read it. Specs call for anywhere from about 9 to 17 inch pounds with new bearings. This transaxle measured 13 - 15 inch pounds.
Greg
GregSef is offline
post #9 of 13 (permalink) Old 10-06-2016, 09:30 AM
kredden's Avatar
As they say, necessity is the mother of invention!
Kevin
kredden is offline
post #10 of 13 (permalink) Old 10-07-2016, 07:17 PM Thread Starter
GregSef's Avatar
Done
I'm just about finished.
Greg
GregSef is offline
post #11 of 13 (permalink) Old 02-20-2017, 01:38 AM
IvanS's Avatar
C.6.0164
Greg
Hi Greg
Would you be prepared to make these tools again,, but for money and shipped to Victoria Australia.
I can not get the complete set here and its difficult to find them.
Thanks in advance
Ivan AROCA member Vic Aust.
IvanS is offline
post #12 of 13 (permalink) Old 02-20-2017, 07:08 PM
Jim G's Avatar
Ivan, PM sent.
Jim G is offline
post #13 of 13 (permalink) Old 12-12-2018, 02:14 AM
harigeri's Avatar
C.6.0164
Greg
Hi Greg! Currently I'm in the process of building a perfect transaxle for my 75 TS, and I would need the tools to make it. Can you send me your drawings?
Thanks in advance!
harigeri is offline
