neat way to remove valve guides - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 39 (permalink) Old 10-20-2012, 07:07 PM
FWIW, I've used Bianchi's method on several heads and had no trouble With damage to the head. Visually the bores look fine and there is no evidence of damage on the OD of the guide.
I must admit, I did not measure the bore diameter but the new guides only go in after heating the head, freezing the guides and a bit of persuasion (using the Jim K. tool).
gprocket is online now
post #32 of 39 (permalink) Old 10-21-2012, 09:31 AM
Little Italian's Avatar
Shankle
Shankle used to offer a valve guide that was slightly knurled to replace guides that had gauled the guide bore. I have always just taken the correct valve guide removal tool and driven the guides out. Never had to us a over-sized or knurled guide. Knurling a new guide is not a big deal if you need it. Practically any automotive machine shop can do it or if you have a lath - easy. Always heat the head before driving new guides. Your oven works well here if your wife is not home.
Little Italian is offline
post #33 of 39 (permalink) Old 10-21-2012, 06:49 PM
PSk
My engine builder back in the days when I used to race cars always used to make valve guides with a little step (flange?) on them so they could not drop. Yes this meant he machined up his own and wasted a lot of bronze (material assumed, not sure what they were made out of) but I like the idea.
These sorts of guides were used on my Sud race engine ... I think he machined the head(s) so the little step would go in a recese in the head so as not to upset the valve spring steel washer.
'71 1750 Series 2 GTV:
PSk is offline
post #34 of 39 (permalink) Old 10-21-2012, 08:48 PM
86spider's Avatar
knurling doesn't add metal, it displaces metal leaving grooves and ridges, decreasing the inner diameter which can then be reamed to size.
86spider is offline
post #35 of 39 (permalink) Old 10-21-2012, 09:39 PM
PSk
Correct, but I believe "little_italian" was referring to knurling the outside of the valve guide, not the inside.
PSk is offline
post #36 of 39 (permalink) Old 10-22-2012, 05:26 AM
NMMilano's Avatar
Knurling the outside must be just a temporary fix.
It's generally agreed that the valve dissipates 25% of it's heat through the guide and if the whole guide is not in contact with the head that would affect heat transfer.
Why not just rebore the guide bore and install the proper oversize (OD) guide?
87 Milano Platinum
76 Alfetta GT race car
70 Fulvia 1.3 Rally S
68 Fiat 850
NMMilano is online now
post #37 of 39 (permalink) Old 10-22-2012, 03:32 PM
86spider's Avatar
True, but I was responding to post 28 referring to knurling adding metal.
Wayne
86spider is offline
post #38 of 39 (permalink) Old 10-22-2012, 04:06 PM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
Note that the word added is in quotes. Just as RJs broach is in quotes. I though it may be easier for some to understand that knurling decreases the ID of the guide by "adding" metal rather than describe the actual process.
papajam is offline
post #39 of 39 (permalink) Old 10-22-2012, 05:16 PM
So it should be told in a sarcasm tone "adding" with fingers in the air like a certain ex pez ""I'm not a crook" heheh
1987 black Milano Verde, 1987 (made in 1986)blue $200 gold with ABS and LSD
1972 White spider 2000 Veloce
slyalfa is offline
