Door pin removal - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By carl750
post #1 of 9 (permalink) Old 07-03-2017, 01:47 PM Thread Starter
carl750's Avatar
Door pin removal
This is on late Super (Nuova) ......... the hinge pins are the "split pin" type. Because they are split pin I would assume they come out fairly easily. However, while it looks like there is plenty of room to drive the upper pin "down & out". There does not appear to be room to drive the lower "down & out" .... it would hit the door before it got all the way out ........... and to drive it "up and out" would require a strange curved punch or something to do it. I would appreciate advice from somebody who has done this in the past.
carl750 is offline
post #2 of 9 (permalink) Old 07-04-2017, 07:56 AM
Andrew's Avatar
I remember facing this once, don't recall my solution, and saw a car in which someone cut an access hole. Ugh.
Remove the door, hinges and all, and drive the pin out? Maybe not the answer you want. Drill it out with a right-angle drill fixture? If the pin has a step or offset worn in it, it may be very reluctant to come out. How about an offset rivet driver and air hammer?
Andrew
Andrew is offline
post #3 of 9 (permalink) Old 07-04-2017, 01:28 PM Thread Starter
carl750's Avatar
With a half dozen different diameter and length brass punches they came out ........... top one downward and bottom one upward.
The worst out-of-round is in the hinges attached to the doors.
Now to work on solution.
carl750 is offline
post #4 of 9 (permalink) Old 07-04-2017, 01:55 PM Thread Starter
carl750's Avatar
Looking at parts manual for earlier Super it appears that the hinge on door is welded in place ........ correct?
Hinge on body is bolted in place ........ correct?
Would it be a mistake to try to remove the hinges on the body? ....... to ream out for bushings
carl750 is offline
post #5 of 9 (permalink) Old 07-05-2017, 04:52 AM
GTV-074's Avatar
I am not looking forward to doing my top pin on the front doors of my Berlina.
It would be great if you could put up a few pics. I'd love to see what the pins that came out look like.
I purchased some new pins (see this thread - http://www.alfabb.com/bb/forums/seda...or-hinges.html)
but have yet to fit them. I have a concern as mentioned in the thread.
Cheers,
Paul.
'74 2000 GTV - Robinia Metallizzato, '73 1.3 Giulia Super - Giallo Prototipo, '68 1750 S1 Berlina - Verde Oliva Metallizzato
GTV-074 is online now
post #6 of 9 (permalink) Old 07-05-2017, 02:51 PM
alfavulcan's Avatar
Like car1750, I used different sized punches on the rear door on my berlina, haven't tackled the front yet. Cardisk shows using an odd angled punch for removal. Steck(?) makes one that looks similar that I'm temped to order
87 graduate, 81 gtv6, 91 164s, 73 berlina 79 Mille miglia GONE: 76 alfetta gt, 74 berlina, 85 gtv6, 79 spider
alfavulcan is offline
post #7 of 9 (permalink) Old 07-05-2017, 05:01 PM Thread Starter
carl750's Avatar
Attached is a Internet image (probably clearer than a photo)
carl750 is offline
post #8 of 9 (permalink) Old 07-08-2017, 12:49 PM Thread Starter
carl750's Avatar
Solution
The wear is completely in the hinges ...... the split pin is much, much harder and had no wear.
Here is my solution to these hinge problems.
I installed 8 "Dry-Running Sleeve Bearing with Steel Shell, PTFE-Lined TIN Bronze, for 6mm Shaft Diameter" purchased from McMaster-Carr (#6679k11). These 8 mm OD bearings slipped nicely into the hinges since the old split pins were 8 mm .... I did wrap the bearings that went into the hinges on the door in a 0.003" sheet of shim stock since they were worn so much that bearing would fall through. Not a real "press fit", but good enough.
Then I tossed the 8 mm split pins and replaced them with hardened 6 mm rod that I threaded for 6 mm nyloc-nut. The pins I made were just like the ones that came from the factory with my Giulietta Sprint Veloce. ........... I went retro
All is nice and tight now .......... still need to adjust the lock, but enough for today.
alfavulcan likes this.
carl750 is offline
post #9 of 9 (permalink) Old Today, 07:10 AM
kengta's Avatar
Nice solution. Where did you get the hardened pins and how did you cut the thread or did you cut the thread and then harden.
Loctite will have a retaining compound that could be used to hold the bearings in the hinge. Select a product to suit the gap you encounter. Likely one of their 600 series. Probably would want to put the pin through while compound sets.
https://www.henkel-adhesives.com/ca/...compounds.html
Regards
Ken
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is offline
