Giulia and Berlina Picture Roll-call - Page 108 - Alfa Romeo Bulletin Board & Forums
 359Likes
post #1606 of 1681 (permalink) Old 02-25-2019, 11:21 PM
JoorZ105's Avatar
my new berlina since oktobre last year.
changed the footpump to a pushbutton, to work with an electric pump for the window washer
Did some work on the engine (alu carb mounts etc)
And some work on the fron suspension (koni, AH kit A, adjustable camberarms, goodridge brakehoses)
At the moment I am working on the rear suspension.
Still have to tune up the engine en place tinted 2000 berlina windows.
Loving it!
pinshaw, spirito, Anfanuts and 3 others like this.
JoorZ105 is offline
post #1607 of 1681 (permalink) Old 02-26-2019, 02:14 PM
jg1053's Avatar
A really nice example, beautiful.
jg1053 is offline
post #1608 of 1681 (permalink) Old 02-26-2019, 03:14 PM
GTV-074's Avatar
Congrats... sweet car!
I'm doing my front suspension at the moment and then need to do the rear.
I love the S2 steering wheel over the S1 Black 'plastic' one, so I swapped mine to an S2 (original stored away).
It is one of the prettiest interiors of any 105 series, if I do say so myself!
Cheers,
Paul.
'74 2000 GTV - Robinia Metallizzato, '73 1.3 Giulia Super - Giallo Prototipo, '68 1750 S1 Berlina - Verde Oliva Metallizzato
GTV-074 is online now
post #1609 of 1681 (permalink) Old 02-26-2019, 05:33 PM
pinshaw's Avatar
Must be suspension month, I finished my rear and have the front torn apart
Took out orig shocks on all four corners, how does that even happen to not change shocks in 46 years?
crazy!
Should drive a whole lot better when done
Cheers
Peter Inshaw 59 Touring Spider 2.0, 63 Spider 1600, 67 GTV 1750, 67 Giulia Super Project, 73 Berlina TS, 91 Spider Veloce, 2018 Stelvio TI Sport
pinshaw is offline
post #1610 of 1681 (permalink) Old 02-27-2019, 09:30 AM
perholmen's Avatar
Originally Posted by tarnow View Post
Here's my Next Big Thing; '69 US 1750, converted to single booster and Webers. It's cold here in Chicago.
Looks great - and good color scheme. Interesting to see that the center console looks like it is a S2 while the car is S1.
Mine is a S2 and has same center console but with hanging pedals.
And unfortunately with 2000 headlights and grille - but am planning on retrofitting the 1750 front when I find the headlamp frames somewhere.
Current - 1750 Berlina. Past - Giulia x 3, 75 Evoluzione, 155, 156, 146, Lotus Europa, Jaguar 420G and many more.
perholmen is offline
post #1611 of 1681 (permalink) Old 03-03-2019, 06:32 PM
pinshaw's Avatar
Did my front suspension today. Not too aggressive, but def more firm than before. Once I get it on the road, I’ll get s feel for how it handles n go from there. Know I want to replace sway bar in front with a later spider version but rear is up in the air.
pinshaw is offline
post #1612 of 1681 (permalink) Old 03-04-2019, 10:56 PM
JoorZ105's Avatar
why is the rear not lowered?
When you get it levelled (or the rear lower then front) drivability is soooo much better.
JoorZ105 is offline
post #1613 of 1681 (permalink) Old 03-04-2019, 11:06 PM
JoorZ105's Avatar
Still trying to find time to finish my berlina.
This will be what I am aming for (same springs and dampers) in ride hight.
Alfa Romeo Berlina 2000 1972 SOLD!
JoorZ105 is offline
post #1614 of 1681 (permalink) Old 03-04-2019, 11:08 PM
pinshaw's Avatar
Had to reread my post to get why you would say that. Up in the air means undecided. Not literally up in the air, but the decision to keep the rear sway bar is. Lol. Car is lowered front n back n is perfect stance wise. Cheers.
pinshaw is offline
post #1615 of 1681 (permalink) Old 03-05-2019, 05:51 AM
101/105guy's Avatar
Nice Berlina!
pinshaw likes this.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #1616 of 1681 (permalink) Old 03-05-2019, 10:20 AM
pinshaw's Avatar
yes that is how mine is now
pics make front look a little lower, but adj front is easy
I left in the spring perches and added spacers on driver side to add .25" for driver wt
easy enough to put in spacers to drop pan down or go with AH 2.25" spring kit which is super simple to pull spring, adj and reinstall
it eliminates heavy alfa spring n lower pan, adds angle to reduce spring factor rate and adds a drop link connection for blade sway bar
have that setup on my GTV
good luck with your project
seems like a lot but worth it in the end
pinshaw is offline
post #1617 of 1681 (permalink) Old 03-07-2019, 10:52 AM
Sunday drive..
spirito, Gasolina, GTA R and 4 others like this.
Biancospino is offline
post #1618 of 1681 (permalink) Old 03-07-2019, 11:52 AM
GTA R's Avatar
Beautiful Car !
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
post #1619 of 1681 (permalink) Old 03-11-2019, 11:58 AM
Gasolina's Avatar
A little late.. I took the picture when my Super turned 50 years at February 28th
Hmm, any way to turn it 45 deg..?
deepblue, evi and 1300TI like this.
Giulia Super "Biscione" 28th February 1969
Gasolina is offline
post #1620 of 1681 (permalink) Old 03-11-2019, 06:40 PM
xplorutah's Avatar
Flip
Hope that works...sorry how I do this kind of ruins the quality fo the pic for some reason. Still working through the quirks of the app.
Gasolina likes this.
1960 Land Rover Series II, 1972 AR Giulia Super 1300
xplorutah is offline
