Headlight switch: is it repairable? - Alfa Romeo Bulletin Board & Forums
post #1 of 12 (permalink) Old 04-02-2013, 12:37 PM Thread Starter
1967 Giulia Super:
I have power going into my headlight switch and none coming out for either the regular or highbeams. The dash lights work though.
Does it come apart so that I can clean the contacts or do I just need to buy a new one?
Todd
'59 Sprint '71 GTV
toddfiebig is offline
post #2 of 12 (permalink) Old 04-02-2013, 02:07 PM
101/105guy's Avatar
People have taken these apart and cleaned the contacts and connections.
The parts are held together by long brass rivets.
New ones are available, but the price is high and the quality is not as good as the originals.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #3 of 12 (permalink) Old 04-02-2013, 02:38 PM Thread Starter
Headlight Switch
So I would have to drill out the rivets and find something to replace them with.
Maybe I can just use a small nut and bolt to replace the rivets?
Has anybody done this?
I am not too excited about the high cost of a new switch that may not be great quality.
Todd
'59 Sprint '71 GTV
post #4 of 12 (permalink) Old 04-02-2013, 02:43 PM
101/105guy's Avatar
If you have a good hardware store nearby, they may have long alum. or brass rivets.
I know my local ACE store has quite a selection !
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #5 of 12 (permalink) Old 04-02-2013, 03:45 PM
Alfajay's Avatar
Originally Posted by toddfiebig View Post
Maybe I can just use a small nut and bolt to replace the rivets? Has anybody done this?
Yes. Use small screws (#6 or #8, I forget which) to replace the small rivets, and nothing to replace the large. The two screws that attach the switch to the steering column go through the large rivets, so if they are drilled out and not replaced, those screws will serve to clamp the switch halves together.
Incidently, there are many threads on the BB about repairing these switches.
Alfajay is offline
post #6 of 12 (permalink) Old 04-02-2013, 05:36 PM
If it is the same switch that was used in S2 Spiders then you can clean up the contacts without removing the switch. Find a thread that has pictures showing the three locations where you can get at the contacts.
2011 Jaguar XKR
alfaparticle is offline
post #7 of 12 (permalink) Old 04-05-2013, 08:17 PM
fangio8c's Avatar
Todd - I think I have a decent used switch. There are (at least) two different types, but you and I have the same year Super. PM me if you are interested.
Gone but not forgotten:
1970 GTV 1750 S2
1967 Giulia Super
fangio8c is offline
post #8 of 12 (permalink) Old 04-06-2013, 05:34 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
This is all well documented on the BB. Have you done a search, yet?
ossodiseppia is offline
post #9 of 12 (permalink) Old 08-23-2019, 12:39 PM
I'm searching all over the place. Can you point me to where it is? I know I saw an exploded view or disassembly instructions somewhere but now I can't find it.
any help would be appreciated.
mhunger is offline
post #10 of 12 (permalink) Old 08-23-2019, 04:19 PM
USTA BE AN AD-MIN
What have you done to test the switch?
post #11 of 12 (permalink) Old 08-23-2019, 04:31 PM
it won't turn off. this has happened to me before. the contacts are carbonized. last time I found disassembly instructions, took it apart and cleaned it. this time I can't find the instructions.
mhunger is offline
post #12 of 12 (permalink) Old 08-23-2019, 05:33 PM
USTA BE AN AD-MIN
You will need to remove the steering wheel and the two part plastic cowling to access the headlamp switch. Once you remove the switch, you will be able to see the contacts. The picture below shows two of them. The other is on the other side. Open the contacts and insert a piece of emery cloth. Close the contacts and pull the emery cloth out. Repeat as necessary to clean the contacts.
