Flaminia Coup -the Bugatti-Wagen- - Page 8 - Alfa Romeo Bulletin Board & Forums
 92Likes
post #106 of 557 (permalink) Old 08-31-2014, 05:16 PM
PSk
I understand and agree with you regarding tools. I've found that making little tools or jigs can make a job considerably easier and actually save time. Now my little tools or jigs are not necessarily pretty but they do the job and often are cut up later and turned into something else.
I look forward to being able to one day purchase a small lathe for my now bigger shed. I used to have access to one but no more and I really miss it .
I will continue to watch your progress with interest and admiration.
'71 1750 Series 2 GTV:
PSk is offline
post #107 of 557 (permalink) Old 09-09-2014, 09:09 AM
flaminiagt's Avatar
Hi Hubert,
I've been enjoying your thread for some time now having recently completed the restoration of my Flaminia GT i can really appreciate what you are doing. Your skill and attention to detail is amazing. Well done.
I see you are now selling your radiator cowling via a trader in the Netherlands (they are even using your pictures in this thread to market them). Is it possible to get one from you?
Regards
Dave
flaminiagt is offline
post #108 of 557 (permalink) Old 11-03-2014, 12:46 PM Thread Starter
improving
Tedesco's Avatar
Project on hold
Please allow a couple of pics only indirectly related to the Bugatti-Wagen. I will move the shop to a new location. Car projects have to wait until the renovation works are completed. The shop will be located in the hall, the barn will be the parking lot.
Promise to turn back to car related topics next time
Flaminia GT 3C, Flaminia Convertibile 3C, Flavia Convertibile 1.8, A112 Abarth, Flaminia Coupé 2.5, Fulvia Sport 1.3S, Unimog U900
Tedesco is offline
post #109 of 557 (permalink) Old 11-03-2014, 07:57 PM
davestebs's Avatar
What a beautiful workshop! And location. I love those windows.
I am moving mine too, but the buliding is tin, not brick.
Dave
Drivers: '63 Spider '74 Berlina
Projects: '58 Sprint, '59 Flaminia berlina, '63 Appia Berlina, '63 Flavia coupe, and Bernie the Berlina.
davestebs is offline
post #110 of 557 (permalink) Old 11-04-2014, 04:42 AM
Fantastic ! This will be like a more intimate version of La Cavalleria of Mario Bernardi in Hann. Münden.
In the workshop I strongly recommend that you consider adding hydronic radiant heating tubes in the floor, within a thin leveling pour of new concrete. I have this in my new garage/workshop, and the added comfort in winter is unbelievable. For fast recovery when a door is opened, I also added an air heater with fan running off the same boiler. The heated slab must be carefully insulated, however, or heat loss to the surrounding structure can get expensive.
Also, polyaspartic floor finish is vastly better than epoxy.
Best wishes,
Don
don000 is offline
post #111 of 557 (permalink) Old 11-04-2014, 08:17 AM
mbaum's Avatar
I need to move back to Germany with the cars and get something like this. What am I doing in LA anyway?
Great property!
Mike
60 Citroen ID - 62 Lancia Appia Vignale Convertibile - 64 Giulia TI - 69 Porsche 911S Targa (Soft Window) - 72 Junior Z 1600
mbaum is offline
post #112 of 557 (permalink) Old 02-04-2015, 11:56 AM Thread Starter
improving
Tedesco's Avatar
I must post these pics! Floor screed to come as soon as the temperatures climb above zero.
Don, you see that I am following your advice.
Tedesco is offline
post #113 of 557 (permalink) Old 02-04-2015, 12:43 PM
hufo's Avatar
As an Architects what sould I say ...
Brilliant Tedesco!
Perhaps I will make you once a visit ,its not so far from Nürnberg.
hufo is offline
post #114 of 557 (permalink) Old 02-04-2015, 02:09 PM
Hubert,
That is fantastic. The installation appears to be very professional. The loops are closer together than typical here in the US, so it uses more tubing but you will have more consistent warmth.
If you will have a two-post lift it would be wise to install the anchor bolts before your pour. Drilling into a hydronic floor is excitement better avoided, although it can be done with the help of a thermal imager.
May I ask what type of sheet material was used underneath ? Does it insulate ?
For my garage in a cold place (Vermont) I also installed a hot air blower using the same Viessmann boiler as for the floor tubing, thinking that it would be necessary for quick recovery after I opened a door. It has proven to be completely unnecessary, a wasted investment. The warm floor heats everything in the room, so the introduction of a bit of cold air from opening a door has surprisingly little effect within my well-insulated structure.
Another suggestion that I think would make you happy is to utilize T5HO fluorescent lighting, as used in many car assembly plants. In a garage of 117 square meters I have ten fixtures, each with four 54w T5HO tubes under a clear polycarbonate cover. The illumination is spectacular - it is often much brighter inside my garage than outside ! It is best to have multiple switches to be able to utilize only the fixtures needed, as the power consumption can be formidable even though the tubes are extremely efficient.
Best wishes,
Don
don000 is offline
post #115 of 557 (permalink) Old 02-05-2015, 12:53 AM Thread Starter
improving
Tedesco's Avatar
Don, thanks for the comments.
In pic 4 you see a square in front of the wooden posts. That is a base plate made of 40 cms of reinforced concrete without disturbing tubes or any other installation. I chose a base-frame-free two post lift with lifting motor at each of the posts. These are electronically synchronized. I will post pictures of it.
The layout of the heating provides the maximum possible warmth from the technical side. Due to the age of the building I want to have as much power reserve as possible. I am quite sure that the system is oversized. Meanwhile I found out that the walls are "double shell" type with an air space in between. Serves as insulation. The ceiling has an insulation (old) as well. But it is ugly, I will replace that in a later step.
The ground is covered by insulation panels. http://www2.basf.de/en/produkte/plas..._startpage.htm
The gate will be replaced by an insulated one, so that only the windows will remain as warmth leaks. I will keep the old windows, because they are responsible for the character of the building, but if really necessary there is space to have better ones installed from inside additionally.
There are five light circuits.
1+2: 2 times 4 tubes above the work benches
3+4: There will be one technical workplace (the lift) and one panel beating workplace. Each of them is illuminated with four 50W LED-lights, one switch per workplace. There is "warm white" and "cold white" available. Warm white is comfortable for the eye and cold white is extremely bright. I equipped each workplace with 2 of each, so it is bright and cosy at the same time. (That´s contradictory, but you know what I mean)
5: The other areas are lighted by another 4 50W warm white LED-lights.
Hufo, Technoclassica in Essen always is an opportunity, I am about 40 kms away from there, and there will be a stand of Lancia Club Deutschland.
Best reagrds
Hubert
Tedesco is offline
post #116 of 557 (permalink) Old 02-05-2015, 10:58 AM
Hubert,
Many thanks for your interesting reply. I had been wondering about that "island" among the tubes. The same type of XPS insulation panels are used in the US, under my garage floor 4 inches thick.
The old windows really are beautiful, and I imagine that they will be OK if air infiltration can be controlled, especially if they face south. Perhaps there is some way to use insulated shutters or shades to limit heat loss at night.
I hope that you will be happy with the LED lights. Throughout my house I used different types, all 2700K (warm). They give a good effect, but some experimentation is necessary to find the right dimmer. In the garage I wanted more even lighting throughout the space, which the long tube fixtures provide, as compared with the concentrated points of light typical of LEDs.
Before you pour the slab you might want to consider installing some lights in the floor, shining upward under the lift.
This will be really a beautiful place.
Best regards,
Don
don000 is offline
post #117 of 557 (permalink) Old 02-06-2015, 11:59 AM Thread Starter
improving
Tedesco's Avatar
Don,
you are right, the tubes give the best light for workplaces, especially regarding your own shadow when you are leaning over your work. That is why I have them above the work benches. I had some talk with my electrician about the light emission of the different types of lights. He told me that a 54W tube would emit 4700 lumen whereas the 50 W LED would bring 4300 lumen. Considering the directed emission of the LED and the "all around" emission of the tube, the LED provides higher light concentration in the lighted area, even if you use reflectors on the tubes as well.
But the aspect which led to my decision is far away from light emission figures and shadows. I wanted to have as small units as possible, best would have been invisible ones.
What I will do, is place a bench and a garden table in front of the shed, and do the work outside in the sunlight.
If the LED lights will not do well, I will replace them by tubes and use them as illumination of the barn instead.
And the floor lights? They died before they were born. I was a bit careless and told my wife about this gorgeous idea, in a kind of subordinate clause(?). Her peek was beyond words, when she said something not so pleasant meaning "enough is enough". So I decided to keep the floor as a floor and not more. Harmony among the family is so important, especially knowing that my wife could have asked me to have a sweet little holiday cottage at the shore of Lago di Como instead of this weird "Farm".
Best regards
Hubert
Tedesco is offline
post #118 of 557 (permalink) Old 02-06-2015, 09:14 PM
Hubert,
Ah yes, with the raised eyebrow we perceive our limits. But in my experience, six months later she will ask 'where are those lights you were going to install, they would have been a good idea ?'
On the shores of Como there are many fine hotels, but where else can a man work in a shop like this ?
Best regards,
Don
don000 is offline
post #119 of 557 (permalink) Old 04-12-2015, 10:17 AM Thread Starter
improving
Tedesco's Avatar
The Bugatti-Wagen has arrived at its new home
No welding, milling, drilling yet, but at least my cars have arrived at "The Farm".
Restoring an old building needs different skills than doing the same with a car, but on an abstract level you are running the same curve.
Have to show the Flavia, too!
Tomorrow the lift will be installed. I wonder if I will be able to do all the gearbox changes etc. without lying on a cold dirty floor holding it on my belly, adjusting it with the knees, the wrench between my teeth.
Will keep you informed.
Tedesco is offline
post #120 of 557 (permalink) Old 04-12-2015, 10:32 PM
Hubert, you are getting soft. There is nothing like balancing a gearbox, or even better a transaxle on your chest whilst lying on a dusty garage floor and feeling for that spanner you knew you put down just beside you.
I am extremely jealous, that workshop looks superb.
Richard J
'65 Giulia Ti, '69 GT Junior, 72 Spider, '74 2000 GTV, ,`00 156
alfavirusnz is offline
