Flaminia Coup -the Bugatti-Wagen- - Page 35 - Alfa Romeo Bulletin Board & Forums
 75Likes
post #511 of 519 (permalink) Old 09-04-2019, 09:05 AM
Giovanni1985's Avatar
Hi Hubert, in the volume calculations do you also consider the thickness of the head gasket?
Giovanni1985 is online now
post #512 of 519 (permalink) Old 09-04-2019, 11:26 AM Thread Starter
improving
Tedesco's Avatar
Yes, I did. What I did not include in the calculation is the fireland and the space left because the piston does not exactly go up to the surface of the block but stays below it some tenth of a mm (if I m not mistaken).
Hubert
Flaminia GT 3C, Flaminia Convertibile 3C, Flavia Convertibile 1.8, A112 Abarth, Flaminia Coupé 2.5, Fulvia Sport 1.3S, Unimog U900
Tedesco is offline
post #513 of 519 (permalink) Old 09-04-2019, 11:31 AM
have you ever tried to do a compression test on one of the newly rebuilt engines?
post #514 of 519 (permalink) Old 09-09-2019, 11:15 AM Thread Starter
improving
Tedesco's Avatar
Giovanni, your proposal almost made it.
Eleven studs could be removed. Welded original nuts from which I had removed the plastic rings to the studs and let them cool down. Where possible I heated the area around the stud in question with the torch and tried to turn it out with the wheel gun.
It took about twice as many nuts to get the pieces out. A few of the studs cracked where they come out of the head. These will have to be milled out. Let´s see how the other head turns out.
The four on the right were not stuck
Hubert
PSk likes this.
Tedesco is offline
post #515 of 519 (permalink) Old 09-09-2019, 09:54 PM
Wow, honored to have contributed to a step forward. The remaining uses the milling machine?
you could try screwing new lubricated pins and making a last attempt with the extractor.
now the resistance will be much less and maybe the twist in the broken pins has decreased friction.
This reminds me of when I opened the water pump of my 2800, all the broken pins, in the 2500 instead no broken ...
Giovanni
post #516 of 519 (permalink) Old 09-12-2019, 11:24 AM Thread Starter
improving
Tedesco's Avatar
Panel beating
Worked on the last but one panel that has been sitting for some weeks. It turns out to be not the best panel ever, I missed the correct measures so that some corners need to be patched. Finally, I messed it all up with the beads, which are not presentable at all. Anyhow, nobody will see this panel again, once the car is assembled. This is not quality thinking, I know, but . . .
Docked a spare but freshly rebuilt Flaminia 2.5 1C to the Schenck. The adopterplate I had made recently turned out to be not fitting hence a new one had to be manufactured. The auxiliaries have to be installed yet. This will take place in my spare time (meaning in between).
Equipped the engine frame with quick-lifting-axles enabling me to place an engine on it by means of my overhead crane which is located close to the lift and then push it over to the Schenck. (Did I talk about that before? Don´t remember)
Ordered custom made head gaskets and pistons for the 3.0l. The gasket guy will pay a visit to “The Farm”. He worked for Goetze for more than ten years and has some experience in engine test stands. Could hear some tone of disbelief in his voice, when we were talking about the forty year old analog unit.
PSk and 1750GT like this.
Tedesco is offline
post #517 of 519 (permalink) Old 09-13-2019, 12:40 PM Thread Starter
improving
Tedesco's Avatar
Originally Posted by [email protected] View Post
Do the pistons have any dome to them?
Geoffrey,
the "dome" (ball scraper) on the standard 2.8 piston is 1,65 mm high on a base radius of 39,5 mm, the radius of the correspondig ball is 474 mm.
Hubert
Tedesco is offline
post #518 of 519 (permalink) Old Today, 06:48 AM
Hubert -
Thanks but can you clarify?
Is the general piston dome having the slight raise, and thus the big radius, and the “bulge” on top of the piston more pronounced, and thus the smaller radius?
Geoff
post #519 of 519 (permalink) Old Today, 10:28 AM Thread Starter
improving
Tedesco's Avatar
Hubert -
Geoff
The piston top is plain with a diameter of 85 mm. The bulge (with a base diameter of 79 mm thus radius 39,5) sits on top of the plain, meaning you have a plain ring of three mms only. The bulge itself is a spherical cap of a ball with the radius of 474 mm, (calotte?).
In other words, cut a calotte of the given size off the very very top of that big ball and place it on a 85 mm dia disk.
Tedesco is offline
