Giannini 1100 - Page 5 - Alfa Romeo Bulletin Board & Forums
post #61 of 98 (permalink) Old 04-11-2012, 01:04 AM
Just stumbled accross this thread: fantastic!!
When ready this car is Villa d'Este material!
Monoposto is offline
post #62 of 98 (permalink) Old 04-11-2012, 05:18 AM
fgsavoia's Avatar
Thank you.
This is the generator (rebuilt and ready to be painted), correctly marked 12/1955:
John, fyi the differential ratio is 10:43
Francesco
fgsavoia is offline
post #63 of 98 (permalink) Old 05-05-2012, 09:34 AM
fgsavoia's Avatar
Work goes on...
We had also to replace the heatshield between cockpit and engine bay.
It was in very good state, but it was made of asbestos....
Francesco
fgsavoia is offline
post #64 of 98 (permalink) Old 06-19-2012, 12:47 PM
fgsavoia's Avatar
Today I felt blue...
Francesco
fgsavoia is offline
post #65 of 98 (permalink) Old 06-19-2012, 03:51 PM
Subtle's Avatar
Wow!!!!!!!!!!
Bob,
Subtle is online now
post #66 of 98 (permalink) Old 06-19-2012, 04:59 PM
hdavis's Avatar
Francesco, one day I will have to make a trip to Milano just to view this car, the amount and the detail of the work you are doing is impressive. Congratulations!
Henry
hdavis is offline
post #67 of 98 (permalink) Old 06-19-2012, 11:41 PM
Cool car!!
1) Ferrari 308 GTB QV 2) MG B GT 3) Mazda MX5 4) BMW 320Ci
Harry_sz is offline
post #68 of 98 (permalink) Old 06-20-2012, 11:53 AM
fgsavoia's Avatar
Thank you guys for the kind words.
Now the car has been painted with the first layer, two more will be done.
I hope to finish the work around the end of july.
Francesco
fgsavoia is offline
post #69 of 98 (permalink) Old 06-20-2012, 11:59 AM
mbaum's Avatar
Simply stunning!
60 Citroen ID - 62 Lancia Appia Vignale Convertibile - 64 Giulia TI - 69 Porsche 911S Targa (Soft Window) - 72 Junior Z 1600
mbaum is offline
post #70 of 98 (permalink) Old 07-23-2012, 02:31 PM
fgsavoia's Avatar
We're almost there....
Francesco
fgsavoia is offline
post #71 of 98 (permalink) Old 08-05-2012, 02:54 PM
fgsavoia's Avatar
"Almost" is a correct adverb...
...because as usual, when the work done is at 90%, then problems arise.
When I bought the steering wheel, I asked to the seller "Are you sure that the hub fits early Fiat 1100?" he answered "Obviously it does".
"Obviously" my a**
The hub hole diameter is actually 1 mm larger than the steering column (which is 18 mm), so now we have to replace it or to rebuild another one from scratch.
My fault for sure, as long as I should have check it better and earlier.
Francesco
fgsavoia is offline
post #72 of 98 (permalink) Old 08-05-2012, 10:38 PM
PG1964's Avatar
May i suggest you to put a "boccola a cilindretto" on the steering column just to see if it fits?
PG1964 is offline
post #73 of 98 (permalink) Old 08-05-2012, 11:02 PM
fgsavoia's Avatar
Never heard about it. Have you some exemple of it or where to find it?
Francesco
fgsavoia is offline
post #74 of 98 (permalink) Old 08-10-2012, 11:16 AM
fgsavoia's Avatar
Thanks Paolo for the suggestion. However, we find another way: bought another hub like this with the correct spline diameter:
then, the spline has been removed from the old hub and then replaced with the one removed from the one just bought, molding the inside of the old one with a lathe and then adding new bolts to fasten it; easy, isn't it?
I expected to finish the work before the beginning of august but that isn't possible. Now it's trimming time:
Francesco
fgsavoia is offline
post #75 of 98 (permalink) Old 08-10-2012, 12:15 PM
NMMilano's Avatar
Attachment 253286
Fantastic picture of a fantastic car.
87 Milano Platinum
76 Alfetta GT race car
70 Fulvia 1.3 Rally S
68 Fiat 850
NMMilano is offline
Tags
boano, giannini
