Do you believe in "global warming?" - Page 180 - Alfa Romeo Bulletin Board & Forums
 285Likes
post #2686 of 2842 (permalink) Old 07-04-2019, 07:45 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
But arguing with the fools on this thread
Oh look
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #2687 of 2842 (permalink) Old 07-04-2019, 08:09 PM
PSk
Maybe some should start with what the purpose of our atmosphere is:
Originally Posted by https://www.windows2universe.org/earth/Atmosphere/overview.html
The atmosphere is a mixture of nitrogen (78%), oxygen (21%), and other gases (1%) that surrounds Earth. High above the planet, the atmosphere becomes thinner until it gradually reaches space. It is divided into five layers. Most of the weather and clouds are found in the first layer.
The atmosphere is an important part of what makes Earth livable. It blocks some of the Sun's dangerous rays from reaching Earth. It traps heat, making Earth a comfortable temperature. And the oxygen within our atmosphere is essential for life.
Yes I try to stop, I do ... but I worry that some here think that just because they are old car enthusiast they have to be climate change deniers. Nobody, in our near future, is going to come to your house and take your treasured Alfa away.
'71 1750 Series 2 GTV:
PSk is online now
post #2688 of 2842 (permalink) Old 07-04-2019, 08:25 PM
PSk
What is a greenhouse gas:
Originally Posted by https://www.windows2universe.org/earth/climate/cli_greengas.html
Even though only a tiny amount of the gases in Earth’s atmosphere are greenhouse gases, they have a huge effect on climate.
There are several different types of greenhouse gases. The major ones are carbon dioxide, water vapor, methane, and nitrous oxide. All of these have molecules with three or more atoms. The atoms are held together loosely enough that they vibrate when they absorb heat. Eventually, the vibrating molecule will release the radiation. The radiation will likely be absorbed by another greenhouse gas molecule. This process, which keeps heat near the Earth’s surface, is called the greenhouse effect.
Almost all of the other gases in Earth’s atmosphere are nitrogen and oxygen. The two atoms in these molecules are bound together tightly and unable to vibrate, so they cannot absorb heat and contribute to the greenhouse effect.
They can test how atoms react in laboratories ...
CO2 is an insulator,
Originally Posted by https://medium.com/@budwilliams/co2-is-an-insulating-gas-it-absorbs-infrared-heat-photons-bc258c9bad47
CO2 is an insulating gas. It absorbs Infrared heat photons.
And there are some stats from NASA in there ... but they tell fibs too ...
And if looking for a healthy debate to read with some numbers: https://earthscience.stackexchange.c...centration-can
I'll pfffffff off now
PSk is online now
post #2689 of 2842 (permalink) Old 07-04-2019, 09:15 PM
kens's Avatar
I just have to share some points from a similar topic on another automotive forum. No credit to me for the observation, credit Mr. Sideways.
#1: CO2 increases food production from crops. This means that the benefits of increasing CO2 have been entirely ignored by one side, and could mean that the world is better off increasing climate change or global warming or CO2 (e.g. solve world hunger).
Note that global poverty/hunger is down.
In other words, the opposite of a catastrophe: Serendipity.
#2: All of the climate models keep failing to predict the future. They have to be revised each year, and the revisions only improve their back-testing, never their forward predictions. This hints at failed "science" or put more plainly: propaganda. One doesn't expect propaganda to have its math check out. Mathematical models are supposed to be checked. It's a core problem when they fail. With "Climate Change" the models fail every year. This thread is over a decade old. That much failure is not a one-off event, yet one side brushes off the failures of the climate models every year.
#3: One side keeps tampering with the temperature data. As documented hundreds of pages ago in this very thread, even NASA hides the raw temperature data (one official NASA link went to Maryland government employee salaries even though it was labeled as Raw Temp Data).
#4: There's a pretty good chance that what is going on is that Nefarious actors are abusing the general Public's good nature to conflate pollution, which the Public dislikes, with some larger goal such as "climate change" in some sort of grand effort to wreck or transfer wealth away from the top 1st World nations.
#5: Sun spots have been at record lows for the entire length of this thread. There is a past historical record of a Maunder Minimum creating a Little Ice Age. That needs to be watched, just in case the opposite is happening from what is being claimed will happen (especially since the climate models keep failing).
164 TB -- 166 Super -- 916 Spider 24V -- Lancia Montecarlo 24V Busso
kens is offline
post #2690 of 2842 (permalink) Old 07-04-2019, 10:17 PM
PSk
Kens, the comment re more CO2 resulting in more plant/food growth ignores the fact that more CO2 means hotter temperatures and more eratic climate, hardly ideal for growing crops.
Just like our Alfa engines, the correct balance/mixture is required, you can't just dump more petrol in
PSk is online now
post #2691 of 2842 (permalink) Old 07-04-2019, 10:22 PM
PSk
According to scientists that study the origins of the earth the combinations of elements, etc. on the earth is a billion to one (something like that) chance and that is exactly what was needed to create life ... and yet you guys think we can happily muck with that balance.
We have already learnt what chloroflurocarbon did to our atmosphere re ozone layer ...
Re controlling the masses, the church has been doing that and does that better than anything we have created
PSk is online now
post #2692 of 2842 (permalink) Old 07-05-2019, 06:03 AM
101/105guy's Avatar
Well, thanks for providing another example of how some are fooled again and again by snake oil salesman and others who make a living from pushing panic.
There was no hole in the ozone. Just another natural cycle.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #2693 of 2842 (permalink) Old 07-05-2019, 07:46 AM
Subtle's Avatar
Originally Posted by GV27 View Post
Just close your eyes and click your heals together and just keep repeating "there's no place like home, there's no place like home". Should do the trick!
When I completed my degree in Geophysics, lecturers reviewed two theories. One was that ice ages were due to lots of precipitation, because somehow the Arctic Ocean was open and the continental masses were frozen.
The other theory was that ice age expansions and interglacials were caused by changes in the amount of energy hitting the Earth.
And this varied due to orbital mechanics.
All that was needed for an interglacial was that each melt season lost more snow and ice than was deposited.
Made sense to me then, but there was not enough evidence to confirm either theory.
Then, in the late 1960s, data started to accumulate and it confirms the orbital mechanics that temp of the climate varies due to changes in the amount of heat received at the Earth's surface.
For me, it has been a fascinating interest for a long time.
If you turn your attention from glib comments to a serious review of the literature, you might find it as rewarding as I have.
Worth the try.
Alfar7 likes this.
Bob,
Subtle is online now
post #2694 of 2842 (permalink) Old 07-05-2019, 08:11 AM
Member
It is also important to understand that there is a very fundamental difference between U.S. citizens and British Commonwealth subjects. In the United States, we citizens are sovereign, not the people in our federal or state governments. In the British Commonwealth of nations, the people are subjects, while the people in government are sovereign, in addition to the Crown.
In the United States, WE THE PEOPLE are having to constantly fight back against those people in government who very much desire to turn us from citizens into subjects. Hence all of these various schemes to tax and control us for their own benefit.
It is not that we are insensitive, but we simply value freedom of choice over a hollow promise of security and fairness from a few people in government.
Alfar7 likes this.
factotum is offline
post #2695 of 2842 (permalink) Old 07-05-2019, 09:21 AM
Alfaboutvegas's Avatar
will it ever end?
Maybe there's a "balance" we all conveniently ignore, hmm.
"No chance, no destiny, no fate can circumvent, change or control the firm resolve of a determined soul"
73 Spider
80 BMW e21(Sold, gone to Houston)
79 Spider (sold)
78 Spider (sold, gone to U K)
Greg
Alfaboutvegas is offline
post #2696 of 2842 (permalink) Old 07-05-2019, 03:23 PM
Tom Frasca's Avatar
Stop the presses!
Yup... that about covers it remember in Geological time we are just a temporary nuisance ....
Tom Frasca is offline
post #2697 of 2842 (permalink) Old 07-06-2019, 03:23 AM
PSk
Rubbish. As I live down here where the hole is, it is 100% true.
Very dangerous down here to be out in the sun, even though temps are low
PSk is online now
post #2698 of 2842 (permalink) Old 07-06-2019, 04:54 AM
101/105guy's Avatar
Just over your place??
Perhaps you are just having some personal sunspots...
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #2699 of 2842 (permalink) Old 07-06-2019, 05:30 AM
sportiva's Avatar
The first three words in this thread are "DO YOU BELIEVE". Do you believe in GOD the resurrection of Jesus and the virgin birth or the man on the moon conspiracy or CLIMATE CHANGE Trying to change a person's belief with a barrage of facts, figures, and theories for or against will make no difference? Arguing climate change theory is pointless.
6alfas, Aggie57 and Tom Frasca like this.
Glen 3.0 GTV6 2.0 156 JTS
sportiva is offline
post #2700 of 2842 (permalink) Old 07-06-2019, 02:55 PM
101/105guy's Avatar
I keep telling them that, but they woun't listen.....
'64 Guilia Spider
'67 GTV
'68 Giulia Super
