NZ Alfa resources??? - Alfa Romeo Bulletin Board & Forums
post #1 of 22 (permalink) Old 12-07-2009, 04:40 PM Thread Starter
I just moved to NZ recently (again - lived here ten years ago) and just bought my first Alfa! I am in ChCh.
I have always done all of my own mechanical work, so I need some advice on where to go for spare parts, accessories, etc.
For basic stuff, who is best, Repco, Butlers, Supercheap ???? Supercheap didn't seem so cheap when Smith's City has carb cleaner for $3.00 less.
What about real Alfa / dealer only parts? Do I go to Euromarque? Or are there other sources? What about special tools like cam locks? Yes, I wll be doing my timing belt soon. Are there any good on line suppliers? It seems like they are all in Europe.
Are any of you members of the local Alfa owners club? Is the club active, whith weekend cruises, etc? I am thinking of joining in the new year.
Thanks in advance for the help.
Avalanche325 is offline
post #2 of 22 (permalink) Old 12-08-2009, 01:39 AM
Stravs's Avatar
I am only an hour down the road in Ashburton if you need anything.
What type of alfa did you get?
For general stuff i go to BNT then maybe to repco.
Specific parts i get shipped in from IAP in USA. Exchange rate is good at the moment.
Good luck with the alfa.
1987 GTV6
Stravs is offline
post #3 of 22 (permalink) Old 12-08-2009, 09:57 AM Thread Starter
I got a 2002 156 2.5l 6 speed Monza. So far I am very happy with it.
I had a friend in the states that had an 86 GTV6. It was my first real introduction to Alfas.
Thanks for the info.
post #4 of 22 (permalink) Old 12-08-2009, 11:01 AM
Hans-Peter's Avatar
Join the club, where to get parts from depends a bit on which model you have got.
Hans-Peter is offline
post #5 of 22 (permalink) Old 12-10-2009, 12:06 AM
For servicing go to my old workshop Italtune in Antigua Street, just off the corner (town side) of Moorhouse Avenue. They can supply parts also but for that late an alfa EB Spares in the UK is pretty good.
Keep an eye on Smiths City I`ve picked up some bargains there -the odd tool, and consumables such as CRC products etc .
Richard J
'65 Giulia Ti, '69 GT Junior, 72 Spider, '74 2000 GTV, ,`00 156
alfavirusnz is offline
post #6 of 22 (permalink) Old 12-10-2009, 01:43 PM Thread Starter
Wow Richard, you have quite a collection there.
Right now I am going to get the parts / tools together to to the cam belt. I got a quote from Speed, and am going to get a quote from EB. They sure are proud of that tensioner, $345.00. Is there anyone around that would have the cam locks and TDC tool for hire or loan?
post #7 of 22 (permalink) Old 12-10-2009, 03:15 PM
I've just ordered the cam locks and TDC tool from Jamie Porter in the UK. The water pump has gone on my 156 so it's a full belts off job. I'd be happy to loan you the tools once I've finished - probably in the new year
Parts Plus in Wellington seem to have access to most common parts for 156s at better prices than the main dealers.
101 Spider, 105 Berlina (x2), 156 2.5 V6, Fiat 125, Mini 1000
Lo Fo SI is offline
post #8 of 22 (permalink) Old 12-10-2009, 03:35 PM Thread Starter
Lo Fo SI,
I appricate the offer on the locks and TDC tool. I just moved from the US, so I am shelling out $$$ like crazy. House, car, furniture, appliances, etc. It would be a help not to have to shell out another couple hundred for tools right now.
I am normally in the mode of buying tools that I need since I do my own work. So if I don't bite the bullet on these, I will take you up on the offer.
How many Kms before that water pump gave up? I was not planning on replacing mine since the labour (me) is cheap if I have to do it later. I haven't noticed any heating problems, so hopfully I don't have the plastic impeller. I took it for a hard run over the port hills yesterday. Nice handling and a great sound.
post #9 of 22 (permalink) Old 12-10-2009, 05:47 PM
The car has done just under 100,000 km and is in pretty good condition for a 12 year old Alfa. I only bought it 4 months ago(because my wife didn't want another car that "you spend all your time fixing"!) The PO had belts etc changed at ~ 70,000 but the pump was not changed so this will be an expensive water pump.
The pump appeared to fail pretty quickly as it was fine on a run over the Rimutakas two weeks ago but started to over heat in about 10kms of 100 km/h driving on Tuesday.
Simon
Lo Fo SI is offline
post #10 of 22 (permalink) Old 12-10-2009, 09:57 PM
You could put a dial guage down the no.1 cylinder to establish TDC couldn`t you?
Then get a white indelible marker pen before dismantling to mark everything, a little bit of steel bar and hacksaw and file to make a cam lock and you should be home and hosed. Generally though my mechanics never used any cam locking tools, nor have I. Most cars I have had anything to do with that had cambelts (including my flat 12 Ferrari) never really required these tools. You just take your time, check, check again, then recheck. 156`s only have the same V6 as 116 GTV6`s don`t they?
Richard J
post #11 of 22 (permalink) Old 12-10-2009, 10:23 PM
Richard - You are right. That is how I've done cam belts on 164s in the past. Didn't even use a dial gauge - just a length of dowel and sensitive fingers! to get TDC. The 156 is supposedly more fragile and is a quad cam with less engagement between belts and pulleys - I'm probably being over cautious in using all the bells and whistles but it can't hurt.
Simon
Lo Fo SI is offline
post #12 of 22 (permalink) Old 12-11-2009, 01:15 AM
Regarding the tensioner I presume you are concerned with the bearing itself/ why can`t you identify the bearing or at least its size and obtain just this from SKF or one of the other bearing suppliers. A local engineering firm can press it out and press in the replacement. I`ve done this several times-you save heaps.
Richard J
post #13 of 22 (permalink) Old 12-11-2009, 09:57 AM Thread Starter
I have done several cam belts before, but never on an Alfa. The TDC tool is just a long extension for the dial indicator that threads into the spark plug threads. I am sure that a DIY is possible for that.
The cam locks - I also thought, why can't everything be marked before the old belt comes off? Every other car I have had has had marks on the cam pullies and a line on the belt. Set at TDC, off with the old, line the marks up as you put the new belt on, and set the tension. Everything I have read about the 156 has said that the cam locks are a must. So I quess that has me a little nervous.
Interesting thought on the tensioner. I would imagine that bearing failure is the concern. Has anyone heard of the spring failing?
post #14 of 22 (permalink) Old 12-11-2009, 12:57 PM
I think if you are experienced and take the approprite care I would be surprised that the cam locks are absolutely necessary-if this is the case it would be unique in the car world. I can imagine it would make life easier and in a commercial environment where getting the job done as quickly as possible is a must it would make the cambelt change a lot quicker. I bet though it can be done without all these special tools by just using good trade practice. confidence is the big stumbling block of course.
Richard J
post #15 of 22 (permalink) Old 12-11-2009, 03:47 PM Thread Starter
I think you are right. I think proper marking and counting belt teeth between cams would do it. Speed of the installation is not an issue. I have never used cam locks on anything else, and an engine is an engine to some extent.
I am sure a dowel and my dial indicator wil be fine for TDC. I have used a screwdiver in the hole on Ford V8s. (I just thought Italian cars needed something more sophisticated) ;-)
Hmmm, now that my in-laws have seen my Alfa, they are looking at one. I may be in for two cam belt changes.
