Setting V6 ignition timing - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 19 (permalink) Old 03-11-2019, 05:40 PM
Alfistaa's Avatar
Factory setting of 2BTDC is for smog, produces hotter exhaust to keep your cat working. For driving, with stock pistons you can safely move to 7BTDC. This is the factory spec for 3.0 Milano. You can add more degrees for better performance, but careful you don't want to cause preignition damage. Higher compression pistons will not allow as much advanced timing as stock pistons.
Alfistaa is offline
post #17 of 19 (permalink) Old 03-11-2019, 07:14 PM
Del
Our 89 Milano Gold, bought new, pinged going up hills with half throttle or more, using regular grade gasoline. Don't know the timing, not touched ever, but have to use mid-grade fuel where we live, sea level conditions. Doesn't do it at Rocky Mountain altitudes with regular grade, of course.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is online now
post #18 of 19 (permalink) Old 03-11-2019, 07:20 PM
Alfistaa's Avatar
Yes, well if you want to use regular gas, by all means stay with 2BTDC.
Alfistaa is offline
post #19 of 19 (permalink) Old 03-13-2019, 03:31 PM
Youz guys make it difficult! All I do is line up the Number One 1 plug wire to the bolt on the valve cover. Been workin' for over 30 years.
Unless some screwed up a timing belt replacement?
AlfasRule!
1972 Montreal (The Pumpkin)
1975 Alfetta Sedan
1975 Alfetta Coupe Race Car
1982 Spider
1984 GTV-6
1984 GTV-6 Verde (GiGi)
1987 Milano (Da NEW Winta Beata)
1987 Milano Verde(Da kREDden Mobile)
alfasrule is offline
