Milano Rear Badge Replacement - Alfa Romeo Bulletin Board & Forums
post #1 of 14 (permalink) Old 04-14-2018, 11:56 AM Thread Starter
So I just swapped out the front grille and badge for the body-colored Euro setup; relatively easy. The rear badge is giving me pause, its on pretty tight, and I can't see the pins to determine whether they're held by plastic grommets like the front. Should I (carefully) use a heat gun to soften the adhesive and then try to pry it off? Thanks to all that have done this before!
VaiVeloce is offline
post #2 of 14 (permalink) Old 04-14-2018, 12:25 PM
They are identical to the front, but mine had a wad of some godawful adhesive also holding it on. I finally got it off after breaking a couple of harbor freight nylon trim tools and folding the badge itself completely in two so i could attack it with a knife. I didnt try a heat gun, but it doesn't sound like a bad idea.
Al
Sent from my LG-SP200 using Tapatalk
radioal is offline
post #3 of 14 (permalink) Old 04-14-2018, 12:39 PM Thread Starter
Thanks Al. Yes, the front badge was original and had a hockey puck-shaped wad of black adhesive on the back. Luckily it just popped off...
post #4 of 14 (permalink) Old 04-14-2018, 01:39 PM
Milano badge
Whats the "body colored Euro setup"?
Milanoverde is offline
post #5 of 14 (permalink) Old 04-14-2018, 02:29 PM
Jamieandthemag's Avatar
Like this
1989 Alfa 75 3.0V6 America - 1971 Alfa Giulia 1300 GT Junior - 1989 Alfa 75 3.0V6 Veloce - 2016 Merc C220 Estate - 2010 Volvo XC60 D5 Polestar
Jamieandthemag is offline
post #6 of 14 (permalink) Old 04-14-2018, 02:32 PM Thread Starter
Euro front grille painted to match the car.
Managed to get the badge removed, but what a PIA! Severely mangled my nylon tools also; needed about five carefully hammered around the badge until I was able to pierce and separate the adhesive puck applied at the factory thirty years ago. Could not save the pin grommets, but I'm sure they're similar in size to other marques.
post #7 of 14 (permalink) Old 04-14-2018, 02:44 PM
I like that look.
Weird thing is mine was only glued in the back. Front came right off with just fingernails. I was blaming mine on some long forgotten body shop since there was evidence of repairs in that area, but i guess it could have been factory.
radioal is offline
post #8 of 14 (permalink) Old 04-14-2018, 03:59 PM
Nakagtv's Avatar
Remember years ago "debadging" friends GTI with a dental floss, was pretty easy. If you can, try sliding it between the tape and the paint and slowly floss as you pull parallel to the body panel. A little bit of heat would not hurt either.
Zaza
Current Alfas:
2018 Stelvio Ti Sport
1987 Milano Verde
1970 Euro-spec GTV 1750
Refreshing 1750 GTV
Nakagtv is offline
post #9 of 14 (permalink) Old 04-15-2018, 01:57 PM Thread Starter
Not sure that clever technique would have worked here, the factory adhesive was very hard...
post #10 of 14 (permalink) Old 04-15-2018, 04:01 PM
I destroyed the bade on my parts car trying to get it off. If the rest of the car was made out of that glue they'd never die.
Ian Lomax - Current: 1973 Berlina, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 164LS
archeologist is offline
post #11 of 14 (permalink) Old 04-15-2018, 07:35 PM
Supporting Vendor
JoeCab's Avatar
Here's a couple of tips:
1) The body color front grill is not strictly European as it came stock on some 1989 Milanos as well. Mostly cars built after 8/88 or so in my experience.
2) If you are trying to remove a rear badge, drill a small hole in it and put a screw into the hole. This will give you something to pull on other than the sides of the badge, which can scratch the paint. If they are really stuck you may have to repeat this technique on 2 opposite sides of the badge.
Centerline International - Alfa Romeo Parts & Accessories
750-ALFA
JoeCab is offline
post #12 of 14 (permalink) Old 04-15-2018, 08:40 PM
Del
"The body color front grill is not strictly European as it came stock on some 1989 Milanos"
Our 89 Milano is like that. Same for the rear Verde spoiler.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #13 of 14 (permalink) Old 04-16-2018, 05:40 AM Thread Starter
Good advice and info, thanks! I used painter's tape around the badge to protect the badge, because I had hopes of salvaging it. But yes, a carefully-placed screw would provide a purchase for vice-grips...
post #14 of 14 (permalink) Old 04-16-2018, 08:09 PM
The better grille.
Brian White - 1979 Alfetta GTV - 1988 Milano Verde - 1981 Lancia Beta Zagato - 2006 Land Rover LR3 - 2005 Audi S4 Avant - 1990 SCCA SpecMiata
bjwhite is offline
