Leak down test - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 11-09-2017, 12:33 PM Thread Starter
Nakagtv's Avatar
Leak down test
Hello Alfisti,
As I was getting ready to put manifolds back on the engine, remembered #6 cylinder that had a clean spark plug when I got the car. After running couple bottles of Motul fuel system cleaner, testing injector (it clicks) and installing new spark plugs, all 6 plugs look the same. But still want to do a leak down test on cylinders to get to know the 3.0 bit better. Also it's easier to hear leaks with manifolds off.
I know firing order is 1-4-2-5-3-6 and need to bring each cylinder to TDC to be tested. Whats a best way to do that, getting TDC on each cylinder without removing the covers off the heads? I have a 1 5/8 (41mm) socket on the pulley to turn the engine and spark plugs are out, what's next?
Any guidance is much appreciated, as I could not find anything on V6 leak down test on here
P.S. I can't remember what is the correct way to install manifold gaskets? Flat side to the engine head, ribbed side toward manifold?
Zaza
Current Alfas:
2018 Stelvio Ti Sport
1987 Milano Verde
1970 Euro-spec GTV 1750
Refreshing 1750 GTV
Nakagtv is offline
post #2 of 8 (permalink) Old 11-09-2017, 01:50 PM Thread Starter
Nakagtv's Avatar
Ok, gonna try looking at the rotor's orientation vs distributor cap. Should tell me which cylinder is on compression cycle right?
Zaza
Current Alfas:
1987 Milano Verde
Refreshing 1750 GTV
Nakagtv is offline
post #3 of 8 (permalink) Old 11-09-2017, 02:09 PM
Gubi's Avatar
I stick a chopstick down the spark plug hole and watch it as I rotate the crank.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #4 of 8 (permalink) Old 11-09-2017, 02:20 PM
Both valid methods. The dowel down the plug opening is more accurate, but the rotor will tell you if you are in the compression stroke. Combining both is not a bad idea.
Whatever you do, don't turn a Busso v6 backwards! You can jump the timing belt. And/or mess up the tensioner.
Al
Sent from my Nexus 5X using Tapatalk
radioal is offline
post #5 of 8 (permalink) Old 11-09-2017, 02:35 PM Thread Starter
Nakagtv's Avatar
TDC V6 engine
Thanks Tom, got that too.
Al
I will do just that Al and thanks. I'm having nightmares of engine turning backwards... don't even look at it backwards, just in case...
Zaza
Current Alfas:
1987 Milano Verde
Refreshing 1750 GTV
Nakagtv is offline
post #6 of 8 (permalink) Old 11-09-2017, 02:39 PM Thread Starter
Nakagtv's Avatar
Manifold Gasket V6
Correct orientation for this?
Zaza
Current Alfas:
1987 Milano Verde
Refreshing 1750 GTV
Nakagtv is offline
post #7 of 8 (permalink) Old 11-09-2017, 02:41 PM
nizam's Avatar
Yup, your intuition is correct.
If you suspect the mating surface may not yield you the best seal to the manifold, I've seen folks coat a thin layer of ultra copper on the manifold gaskets too (should be able to get this at your local auto parts store).
nizam is offline
post #8 of 8 (permalink) Old 11-09-2017, 02:59 PM Thread Starter
Nakagtv's Avatar
Mating surfaces looked good, I'll clean up and take a closer look. Thanks
Zaza
Current Alfas:
1987 Milano Verde
Refreshing 1750 GTV
Nakagtv is offline
