Milano water pump belt fitting - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 02-14-2012, 06:31 PM Thread Starter
Giorgio68's Avatar
Ok guys this is the story......I replaced the water pump and tensioner on my Verde and now I can't put the the water pump belt into the pulley.
There is barely space between the water pump pulley and the crank pulley.
Was I suppose to put the belt on the pulley while I was bolting the water pump, that means every time you need to replace the water pump/alternator belt the water pump needs to be removed that's impossible.....
I am sure there is a trick I am missing.
TIA
[SIGPIC][/SIGPIC]
{Oo==V==oO}
Currently:
'75 Giulia Nuova Super 1300 Blu Olandese
'71 Euro Berlina 2000 (on a restoration process)
'85 GTV6 Nero
'87 Milano Verde
'87 Milano Platinum
{OO==V==OO}
Giorgio68 is offline
post #2 of 3 (permalink) Old 02-14-2012, 07:42 PM
Graham D's Avatar
Okey-dokey. The belt in question goes around the crank pulley to the water pump and then the alternator. If you've released the alternator/tension adjustment and rotated the alternator toward the block as far as possible but you still cannot get the belt over the alternator pulley, your new belt is too short.
Graham D is online now
post #3 of 3 (permalink) Old 02-15-2012, 03:51 AM Thread Starter
Giorgio68's Avatar
Graham my bad.....after thinking about it last night I figured it out that I was missing to put the belt around the crank pulley duhhh. Tonight I will try it and should be fine.
Thanks again!
Giorgio
[SIGPIC][/SIGPIC]
{Oo==V==oO}
Currently:
'85 GTV6 Nero
'87 Milano Verde
'87 Milano Platinum
{OO==V==OO}
