Chassis #915.026. Help. - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 11-21-2018, 10:27 AM Thread Starter
OLEG NAGORNY's Avatar
Good afternoon!
It's the 6C 2500 SS Pininfarina chassis #915.026. Can you tell what it can be (marked with red arrows)? One of them is the steering shaft. What is another pipe? What is this box for?
OLEG NAGORNY is offline
post #2 of 6 (permalink) Old 11-21-2018, 10:44 AM
velocedoc's Avatar
The compartment looks like a tray for your spark plugs and tools. The other pipe looks like a chassis stiffener. That is one beautiful 6C2500 SS!
Christopher
www.alfadoctor.wordpress.com
velocedoc is offline
post #3 of 6 (permalink) Old 11-27-2018, 09:04 AM
PG1964's Avatar
Remember Oleg that the 256 was a racing car and not a series chassis. In particular, this one was the ex-Piero Dusio racing car, bought after the racing season and rebodied in 1940.
PG1964 is offline
post #4 of 6 (permalink) Old 11-28-2018, 10:58 AM
Ex 915 036 competition model on 2700 mm chassis, rebodied by Pininfarina in 1940 as road going car and renumbered in 915 026 (both VINs are visible on chassis frame). The first (black rod) is steering axis and second is tube where handbrake axis is passing (the well in rain gutter I sincerely have no idea).
ARGTAReg is offline
post #5 of 6 (permalink) Old 12-03-2018, 12:11 PM
iicarJohn's Avatar
Piero Dusio (a.k.a. "Pietro Dusio")
"Pietro Dusio" owned 915011 and raced it during 1939. He sold it January 1940 and repurchased it three months later and owned it until 1943. At least, this is what the PRA record has recorded. The chassis 915011 appears 1947 on a listing of cars appropriated by German troops during WWII and the car was seemingly lost after that time.
While it is likely that 915026 had a frame number (number not known to my studies but almost certainly beginning "934xxx") as well as the chassis number stamping "915026", it is unlikely that the original 915026 also bore chassis "915036". It is possible that chassis 915036 was used to repair the car identified today as 915026? It has been stated in the past that Alfa Romeo reported that 915026 had its origins during 1941.
To my knowledge, there is no known history identified for chassis 915036. Please furnish some additional information.
Both 915026 and 915036 are likely to have had frame numbers with the form 934xxx. Generally, this number is stamped on top of the front cross-member (below the radiator) very near the center, and often on the front edge. It can be difficult or impossible to see if the car is fully assembled.
Once again, I am attaching a form that can be used to describe "what is" about any similar car existing today. 915026 and 915036 are close enough in numbering that I'll not say that the component mix can be identified definitively as belonging originally to either the one chassis number or the other, but we may have a chance to make some educated guesses once additional data is collected. It would be nice to learn as much as possible about any similar car!
John
File Type: pdf A4-AR6C2300B-2500-2900-DATAworksheet-2016-11-16-English.pdf (325.8 KB, 32 views)
iicarJohn is offline
post #6 of 6 (permalink) Old 12-10-2018, 12:39 AM
rolf haemmerli's Avatar
Hello Oleg
The gray tube is the steering wheel column, the black tube is a mount for the torpedo when the vehicle was still a racing car. This tube is welded directly to the chassis. The box above
is in my opinion a fresh air intake see bonnet.
I once had spare parts from this vehicle owner bought gearbox, steering column suspensions and many small parts, as well as counters. All with Tipo 256 specifications. If you can say that! According to transmission translation. Unfortunately sold for a long time to Russia.
Have many numbers of the car. But not the chassis no. At the time, the numbers were not that important!
rolf haemmerli is offline
