Different between GTV/GT and GTA - Alfa Romeo Bulletin Board & Forums
post #1 of 13 (permalink) Old 12-21-2003, 09:15 AM Thread Starter
Send a message via MSN to max_75
Question Different between GTV/GT and GTA
Hi guys,
I'm very new to Alfa oldies, but i'm getting interest on it. I'm wondering what's the different between the Giulia GTV/GT and Giulia GTA beside the weight and engine?? Any different in suspension design,weight distribution and etc..??
Thanks.
max_75 is offline
post #2 of 13 (permalink) Old 12-21-2003, 07:18 PM
PSk
I would suggest that you search the internet for Alfa Romeo GTA and you will find lots of information, but I will have a go anyway:
GTA:
  • Alloy body thus weighs heaps less.
  • twin plug engines, etc.
  • Roll centres have been changed in the suspension with the biggest change being the sliding block rear suspension which lowers the rear roll centre.
In the end both the GTA and the GTAm were available with heaps of factory options and thus you could build yourself up a pretty wild machine or not ...
Hope this helps you on the start of this journey
'71 1750 Series 2 GTV:
PSk is offline
post #3 of 13 (permalink) Old 12-22-2003, 12:04 AM
Takis's Avatar
Giulia sprint GTA.
Its looks are the same as a Giulia Sprint GT except the following:
1.Lightweight body constructed from aluminium,magnesium,zinc,maganium given the name Peraluman 25 and attached on the chassis by rivets.
2.Same contruction of the doors and front-rear hoods.
3.different nose grill.
4.lightweight dashboard and bucket seats.
5.different steering wheel.
6.1600 block engine but with twin spark plug head.
7.oil cooler radiator beside different water radiator.
8.magnesium (electron) bell housing.
9.close ratio gearbox.
10.magnesium (electron) differential housing and LSD.
11.sliding block rear suspension.
12.knuckle risers on the front uprights which were also adjustable for different camber angles.
13.magnesium (electron) Campagnolo wheels in 6X14,61/2X14,7X14,8X14.
14.bigger fuel tank 80-90 lt capacity.
15.Weber 45 DCOE carbs.
Takis.
1750 GT Veloce 1a serie
Takis is offline
post #4 of 13 (permalink) Old 12-22-2003, 02:59 AM Thread Starter
so any different on body design?? anyone have pic for a GTV and GTA??
max_75 is offline
post #5 of 13 (permalink) Old 12-22-2003, 07:38 AM
Takis's Avatar
Giulia Sprint GT......
Takis is offline
post #6 of 13 (permalink) Old 12-22-2003, 07:40 AM
Takis's Avatar
Giulia Sprint GTA.......
Takis is offline
post #7 of 13 (permalink) Old 12-22-2003, 07:42 AM
Takis's Avatar
Giulia Sprint GT Veloce......
Takis is offline
post #8 of 13 (permalink) Old 12-22-2003, 01:02 PM
borrani's Avatar
Max_75, there are scores of fabulous books out there on these cars, indulge yourself!
Most of the mods listed here were certainly not on every GTA. Items like sliding block, lightweight dashboard, 90 lt fuel tanks, elektron bellhousings and knucklerisers were Autodelta only. There was no elektron differential housing, but there was the elektron tailshaft housing of the transmission! They all had the lightweight seats, however. Standard they came with the crossover air plenum like a standard GTV.
Final Drive ratios were available as 5.12, standard I think, and up to 5.38. There were around 3 flavors of close ratio gearboxes. Heck, the sliding block wasn't homologated till 1966, so I don't think you'll see that in the FIA Appendix K racing GTA's?
I'd love to see what other owner's GTA's weigh. Mine is a fairly standard race car, no interior to speak of and two 3kg seats. Mine has a standard GTV gearbox and radiator, and no elektron, and weighs 1870lbs. dry (no gas, but oil and water). It has a full wiring harness and wipers. It's FIA legal. Alfa Romeo got them homologated to 1650lbs. I'd love to see how they got these cars that light back in the day!
Happy Holidays,
Steve S.
Seattle, WA
borrani is offline
post #9 of 13 (permalink) Old 12-22-2003, 01:06 PM
borrani's Avatar
borrani is offline
post #10 of 13 (permalink) Old 12-23-2003, 04:39 AM Thread Starter
wah.. that is very expensive man, i can't affort it. actually GTV in my country is quite cheap, i think around $2500 can get a fully restore car, there is only 2 GTA in my country.. so i think if GTA, it's priceless..
max_75 is offline
post #11 of 13 (permalink) Old 02-14-2004, 06:24 AM
If you want to see a real GTA look to this site....
http://www.carclassic.com/html/DM39.htm
fabio is offline
post #12 of 13 (permalink) Old 02-14-2004, 07:01 AM
alfa of-corse
Guest
Posts: n/a
Sports Car Graphic tested both cars when they came out and got these results, keep in mind that this was the stock GTA, not a "prepped" one
GTA STradale 0-60 8.2 secs
1/4 m 16.8
1600 GTV 0-60 11.2
1/4 17.9
the GTA they scaled weighed 400 lbs less than the GTV they tested, it was also rated at a mild 133 hp, 160 hp was more common for prepped cars
post #13 of 13 (permalink) Old 11-29-2004, 06:38 AM
2 GTAs in Malaysia?
Max, I would like to know who has the other one.
chfu is offline
