Any difference between the grille mesh of GTA or GT? - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 04-29-2010, 03:59 PM Thread Starter
feliucro's Avatar
I have seen several types of mesh but I want to have the correct diameters.
Please help with photos and the appropriate distances of the front grille.
Felipe
or
1964 Guilia Sprint GT- 1972 GTV 2000
1973 BMW 2002 Baur-Alpina - 1981 Renault 5 Turbo 1
feliucro is offline
post #2 of 7 (permalink) Old 05-02-2010, 07:50 AM
Berlinista's Avatar
the top one is the best GTA look a like. The bottom GT.
On a GT there are 4 parts. Left and right of the headlamps, outside, a small plastic part. Inside, two parts, with a grille surround , made of the material in your lower picture.
A GTA has the center part in one piece. A different grille heart, looks like a cut down version of a Giulia grille.
Also with a surround. On a GT there is a different grille heart, with two holes in the center covered by the grille heart. The GTA does not have these holes.
The GTA has two oval holes lower in the front valance, covered by the same material as the grille mesh. I would advise you to contact alfaholics for these parts.
Berlinista is offline
post #3 of 7 (permalink) Old 05-02-2010, 05:59 PM Thread Starter
feliucro's Avatar
Hi , thank you for your clarifying, having in mind that car is a GT I going to do only the two oval holes lower in the front valance to make it look better, The rest as original design.
Best regards
Felipe
feliucro is offline
post #4 of 7 (permalink) Old 05-02-2010, 06:00 PM Thread Starter
feliucro's Avatar
Best regards
Felipe
feliucro is offline
post #5 of 7 (permalink) Old 05-13-2010, 09:20 AM
kpc655's Avatar
felipe,
can you tell me what the dimensions are in english? i can't quite translate
hilo = ? google translator can't decide!
i assume wire diameter is 1.1mm
what is the 1.0 x 30 dimension?
i'm also trying to find some of this for my car (Mcmaster carr only has english though..so i'll use something similar)
thanks!
Kevin
kpc655 is online now
post #6 of 7 (permalink) Old 05-13-2010, 10:03 AM
quadrifolio's Avatar
dimensiones=sizes 1meter x 30meters, should be a hole roll i think, hilo=wire
cheers
quadrifolio is offline
post #7 of 7 (permalink) Old 05-13-2010, 10:05 AM
kpc655's Avatar
ahh, understood. thanks!
any idea what the density of the wire should be for an application like this? (now many squares per inch or so..)?
