New Motor - Alfa Romeo Bulletin Board & Forums
 5Likes
  • 5 Post By gigem75
post #1 of 9 (permalink) Old 08-10-2019, 08:21 PM Thread Starter
gigem75's Avatar
New Motor
I kept my foot out of it until I didn't. Break in complete.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #2 of 9 (permalink) Old 08-11-2019, 04:51 PM
Wow! That engine seems like it pulls really well. Sounds great too!
Lindy911 is offline
post #3 of 9 (permalink) Old 08-11-2019, 06:35 PM Thread Starter
gigem75's Avatar
Thanks! It was a good 100 degrees when I shot that.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #4 of 9 (permalink) Old 08-13-2019, 06:45 PM Thread Starter
gigem75's Avatar
I did my redneck data logging AFRs on my new motor with the higher compression Alfaholics pistons. My first runs were with 135 mains and 220 ACs. That was to lean.
Then with 135 mains and 210 ACs which gave me [email protected]
and then 130 mains and 200 ACs which was [email protected] I decided on the 135 and 210. The pull in 4th from 2000rpm was smoother with this as well.
The complete jetting is:
135 Mains
210 AC
f11 tubes
34 chokes
55f8 idle
Ed and anyone else, what do you think.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #5 of 9 (permalink) Old 08-13-2019, 09:28 PM
It depends upon where the AFR is at lower RPM under WOT and at part throttle. If it is generally lower than 13.0 then I would try 130 MJ and 190 or 180 AC.
AC size mainly affects high rpm AFR and has little effect on part throttle. MJ affects everything to some degree.
F11 is an unusual choice of emulsion tube for a Nord motor. The factory used F9 or F16. You will almost certainly end up with different main jets and air correctors than someone using F16's on a similar motor.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #6 of 9 (permalink) Old 08-14-2019, 07:19 AM Thread Starter
gigem75's Avatar
Thanks Ed. yes f11s are unusual but not uncommon either. I'm happy with the WOT afr and the cruise afr bounces around 13, sometimes a little under and sometimes a little above and sometimes right on 13. It's set up to where when I'm loping along under no "load" in 4th in and around 2.2k rpm at a steady throttle it runs smooth with no burping just a steady drone hitting on all four all the time. Again thanks. I have confidence I won't be burning a hole in a piston.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #7 of 9 (permalink) Old 08-14-2019, 07:39 AM
You won't burn a piston by running lean at part throttle. My GTV6 deliberately runs in the 15's at cruising conditions @ 60 - 80 mph. I agree that if you are not running rich at WOT in the sub 5000 rpm range then 135 is probably the right MJ.
85 GTV6 3L
2011 Jaguar XKR
post #8 of 9 (permalink) Old Today, 03:28 PM
SouthBayGtv's Avatar
https://youtu.be/rmTwPwZHmqo
😳 so whats new from the engine you built in my car? Pistons / Cams / Distributer? Exhaust different too i gather... still with webber 40s? Seems to rip a lot harder than mine. Very nice!
Current Garage: 18' TRD Pro 4Runner (DD), 13' Ducati Hypermotard (Canyon Express), 74' GTV 2000 (Soon to be Outlaw'd) Work: www.trahanphoto.com
SouthBayGtv is offline
post #9 of 9 (permalink) Old Today, 06:42 PM
Sounds very nice Mike. Congratulations. Don't let your friend drive it.
85 GTV6 3L
2011 Jaguar XKR
