On/Off Wiper (1. speed) no automatic park position? - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 08-31-2018, 07:07 AM Thread Starter
Toli0815's Avatar
Hi There,
My '67 Junior is equiped with on/off windscreen wipers... either they're on... either they're off (no fast speed, no intermitent).
my dash two way toggle switch, activates or stops the wipers... so far all normal for a series 1.... but actually I was wondering if there was something alfisticial meant to be like a soft landing automatic park modus for the wiper arms to their lowest position, in shot down position
... or was this kind of function just to consdidered as plain luxury for decadent JAG-RR-MB-Drivers....and thus far to unsporty for the real hairy chested Alfisti i.e long haired, red-lipsticked-fingernailed Alfista?
I ask because, for now I always have to catch the exact switch-off moment as to have the arms in their slowest position possible, otherwise they just stop randomly within the windscreens surface.
This entertaining game is of course a challenging training to maintain my ninja like reflexes/jerks... but its a bit annoying to be honnest.
Any light on this question is appreciate.
Thomas
Thomas Linser
(Jan 1967 1300 GT Junior, in bluette w/oxblood skai inetrior)
Toli0815 is offline
post #2 of 9 (permalink) Old 08-31-2018, 09:25 AM
Alfajay's Avatar
Your wipers should park, but I don't think a '67 would have 2-speed operation and certainly not intermittent.
The mechanism in the wiper motor-transmission unit that handles the park function may be worn out - it consists of tiny, brass contacts and they do fail with wear. Or your motor may be wired incorrectly - there should be a source of unswitched +12V to the motor that powers it between shutting off the dash switch and reaching the park position.
Lot written on the BB about 105 wipers.
Alfajay is online now
post #3 of 9 (permalink) Old 08-31-2018, 09:45 AM
Gubi's Avatar
My guess is that the park switch has failed and the PO has rewired it to "fix" the problem.
Ask me why I suspect this...
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #4 of 9 (permalink) Old 09-01-2018, 02:05 AM
malcolm1's Avatar
My 75 junior was the same when I got it.
The main reason was that the contacts on the foot operated washer pump were disconnected as it was a rusty mess, so worth checking if it is connected and the contacts in good shape - replacement pumps - or conversion to electric washer pump - available.
The wiper switch contacts weren't in good shape either - replacement switches available
And the previous owner had replaced the wiper motor - wrong type - and not connected all of the wires. Replacement motors available.
The wiring circuit is quite complicated, so worth tracking down the right one for your car, if you don't have it.
The wipers should run slow (position 1) or fast (position 2). When switching off they should park. When you press the washer button, it should trigger the wipers (fast). When you release the button, they should park. Intermittent is not featured
1975 GT Junior with 2 litre lump
2006 Subaru Impreza WRX
malcolm1 is offline
post #5 of 9 (permalink) Old 09-02-2018, 01:34 PM
Yachtman's Avatar
Two suggestions.
First, don't drive in the rain. But it sounds like you do, so,....
Second, drive faster. Waaaaaay fasterrrrrrrr............... !
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #6 of 9 (permalink) Old 09-03-2018, 12:10 AM Thread Starter
Toli0815's Avatar
Hi There,
thanks a lot for your input.
AFAIK a '67 or earlier (be it GT a GTV or a Junior) should only be equiped with a 1x speed on/off "tergicristalli"
I will investigate all tech' suggestions you were Kind enough to share and provide (Thanks a lot Malcom1 & Alfajay, Gubi).
1st Step: I will be to check out my Foot-Operated-Washer-Pump (I will try to find the correct match to the version I have currently in car)
2nd Step: I will investigate the Brass connectors on the wiper switches @malcolm1... where can one get these? I never noticed these on the web pages of the usual suspects
3rd Step: I will follow Yachtman's solution (although I do not drive in the rain...you know the story...alfa + water... well...).... I will go faster after washing the car )
Kind regards
Thomas
Thomas Linser
Toli0815 is offline
post #7 of 9 (permalink) Old 09-03-2018, 12:39 AM
malcolm1's Avatar
Regarding the switch, I meant that if there is a problem with the contacts, then replacement switches are available from the usual suspects
https://classicalfa.com/products.php...-TOGGLE-SWITCH
malcolm1 is offline
post #8 of 9 (permalink) Old 09-03-2018, 01:22 AM Thread Starter
Toli0815's Avatar
Dear Jay,
I will do my homework and read myself through... but as always a picture is worth thousand words, do you by any chance have a picture to share of these "tiny brass contacts"
KR
Thomas Linser
Toli0815 is offline
post #9 of 9 (permalink) Old 09-03-2018, 01:26 AM Thread Starter
Toli0815's Avatar
Dear Malcolm,
Thanks for your reply about these Switches I knew these of course... No problem at all with these in my car they work as intended.
But thanks anyway.... I will start with your foot pump suggestion.... seems to be a good place to start with the investigations.
KR
Thomas
Thomas Linser
Toli0815 is offline
