Viva AR-66 Giulia Sprint GT Veloce - Page 8 - Alfa Romeo Bulletin Board & Forums
 108Likes
post #106 of 411 (permalink) Old 07-04-2018, 11:08 AM
JJr
JJr's Avatar
My U.S. 71 wiring harness runs along the sill of the drivers side, my guess would be that the wiring harness runs to the side of the ignition, gauges etc.
I also had a though regarding your in-dash radio, IMO, why ruin a beautiful dash with something that wasn't factory installed? Install a Bluetooth enabled stereo or multi channel amp in the trunk and stream from your iOS device.
JJr is offline
post #107 of 411 (permalink) Old 07-04-2018, 12:24 PM
VeloceRosso's Avatar
Originally Posted by alfa_corsa View Post
I think I recall the general layout and if I'm correct the main harness (from rear to front runs along the passenger side floor. Is there a photo or diagram that shows the general routing that anyone has to share?
-tj in the Cruz Mtns
Tj, not the best photo but it shows the wiring harness on my ‘66 running along the roof line in a channel. Not sure if it’s the same for LHD as mine is RHD.
FWIW, we’re also restoring a later model ‘70 1750 GTV MkII of which the harness is quite different (and improved) and runs along the top of the sill.
Jannes
Jannes
'64 Giulia 1600 Ti, '66 Giulia Sprint GT Veloce, '70 1750 GTV
VeloceRosso is online now
post #108 of 411 (permalink) Old 07-04-2018, 12:38 PM
PSk
Back in 1966 I'm pretty sure no manufacturer factory installed radios, it was done by the dealers. How things have improved in that area
'71 1750 Series 2 GTV:
PSk is offline
post #109 of 411 (permalink) Old 07-04-2018, 07:27 PM Thread Starter
alfa_corsa's Avatar
Send a message via Skype™ to alfa_corsa
Originally Posted by VeloceRosso View Post
Tj, not the best photo but it shows the wiring harness on my Ď66 running along the roof line in a channel. Not sure if itís the same for LHD as mine is RHD.
FWIW, weíre also restoring a later model Ď70 1750 GTV MkII of which the harness is quite different (and improved) and runs along the floor.
Jannes
Thanks Jannes,
I believe thatís the wiring that goes back to the tail lights, fuel tank sender unit, and reverse light, correct? Can you confirm that it is routed up the a-pillar where it emerges at the b-pillar before it gets tucked in to the groove in the roof line?
57 1900C SS (10321) Carrozerria Touring (in process)
59 Giulietta Spider Veloce (05431)
66 Giulia Sprint GT Veloce (242922) Reborn
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
66 Ducati Mach 1 Replica
alfa_corsa is online now
post #110 of 411 (permalink) Old 07-04-2018, 07:29 PM Thread Starter
alfa_corsa's Avatar
Thank you,
I like the look of the period correct head unit, and even though the factory didnít install radios, they were certainly installed by dealers in those days.
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #111 of 411 (permalink) Old 07-04-2018, 07:31 PM Thread Starter
alfa_corsa's Avatar
Originally Posted by Subtle View Post
What a built!
Colour is outstanding.
Thank you Bob,
Itís called Cobalto Blue Medio.
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #112 of 411 (permalink) Old 07-04-2018, 09:04 PM
I believe that’s the wiring that goes back to the tail lights, fuel tank sender unit, and reverse light, correct? Can you confirm that it is routed up the a-pillar where it emerges at the b-pillar before it gets tucked in to the groove in the roof line?
Yes, its the wiring that goes to the trunk for lights and the fuel tank sender unit.
And yes, it does get threaded up the a-pillar. Unfortunately I can’t find a photo now showing this.
Jannes
Jannes
post #113 of 411 (permalink) Old 07-04-2018, 09:48 PM Thread Starter
alfa_corsa's Avatar
And yes, it does get threaded up the a-pillar. Unfortunately I canít find a photo now showing this.
Jannes
Thanks again Jannes,
I think I remember how it gets routed up through the a-pillar.
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #114 of 411 (permalink) Old 07-04-2018, 11:20 PM
Trich's Avatar
FWIW. The harness in my '65 had the rear harness running along the top of the driver's side sill. The only thing which threaded up into the A-pillar was the wiring for the courtesy lights.
My "rejuvenation" blog: http://65tomfoolery.wordpress.com
'65 Alfa Giulia Sprint GT, a long way to go stillÖ.
Trich is online now
post #115 of 411 (permalink) Old 07-05-2018, 08:10 AM Thread Starter
alfa_corsa's Avatar
Thanks Tom.
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #116 of 411 (permalink) Old 07-06-2018, 03:12 PM Thread Starter
alfa_corsa's Avatar
I'm renewing my call to any and all 105 restorers who can weigh in on whether or not the portion of the wiring harness which serves the tail lights, fuel sender, and reverse light is routed in the channel above the door and rear window and down the c-pillar. There is a groove on both sides of my body with tabs that appear to be for holding the harness in place, and I've seen at least a couple cars with their apparently original harnesses in that area.
IMG_9093 by gearheadexchange, on Flickr
IMG_9094 by gearheadexchange, on Flickr
I've heard some report that their harness ran along lower door sill on the floor of the driver's side of the car as well. It's possible that Alfa Romeo installed the harness in both locations for some reason.
If you've got an opinion or experience to share, please do!
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #117 of 411 (permalink) Old 07-06-2018, 04:45 PM
Ranz's Avatar
1967 1600 RHD GTV....under the LHS sill plate.
Ranz is online now
post #118 of 411 (permalink) Old 07-06-2018, 04:50 PM
Alfajay's Avatar
My experience agrees with trich and Ranz: LHS sill plate.
But I can see pros and cons of putting it in the roof structure:
+ Less likely to be damaged from stepping on sill plate
- In the unlikely event that the wiring did get damaged, you would need to remove your windshields and take out the headliner to access it.
pinshaw likes this.
Alfajay is offline
post #119 of 411 (permalink) Old 07-06-2018, 04:53 PM
r-mm's Avatar
Sill plate for sure on my Ď73. It seems a lot more logical to me - dealing with the Headliner is probably the hardest thing to do right. on these cars.
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is online now
post #120 of 411 (permalink) Old 07-08-2018, 12:10 PM Thread Starter
alfa_corsa's Avatar
I'm installing the pedal box, brake master cylinder and linkage. Does anyone know what kind of fasteners are used to mount the brake MC to the pedal box? Is it a long bolt with a special head? I can't recall what was in there before I removed it and it seems that a standard hex bolt obstructs the linkage.
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
