Tyre Choice 195 60R14 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 17 (permalink) Old 10-26-2017, 11:50 AM Thread Starter
getv2000's Avatar
Any suggestions for tyres on Cromodora style wheels size 195 60 R14?
getv2000 is offline
post #2 of 17 (permalink) Old 10-26-2017, 12:06 PM
Pirelli CN36 185/70/14
Joe
joegt3cup is offline
post #3 of 17 (permalink) Old 10-26-2017, 12:55 PM
Tom Frasca's Avatar
Depends on use daily or recreational if rec. go for Dunlop DIREZZA ZII STAR SPEC - SIZE: 185/60R14
very grippy and wear sorta ok..if not agree with Joe.....BTW just saying from the picture seems like a lot of positive caster does the car jump around alot...??
Tom Frasca is offline
post #4 of 17 (permalink) Old 10-26-2017, 01:00 PM Thread Starter
getv2000's Avatar
Thanks will check both of them
getv2000 is offline
post #5 of 17 (permalink) Old 10-26-2017, 01:43 PM
Tom Frasca's Avatar
Still curious about the handling, is the car jumpy at speed in a straight line ..??
post #6 of 17 (permalink) Old 10-26-2017, 02:05 PM Thread Starter
getv2000's Avatar
Carvhas not driven a single
Mile since ownership, currently being painted ;-)
getv2000 is offline
post #7 of 17 (permalink) Old 10-26-2017, 02:06 PM Thread Starter
getv2000's Avatar
Need to change the tyres because they are old....
Tom Frasca likes this.
getv2000 is offline
post #8 of 17 (permalink) Old 10-26-2017, 02:10 PM
Tom Frasca's Avatar
While you have the car apart and if everything checks out ... replace the fixed upper control arms with adjustables not expensive and worth every penny..
post #9 of 17 (permalink) Old 10-26-2017, 10:24 PM Thread Starter
getv2000's Avatar
You made a comment about caster, these arms influence camber....
https://m.ebay.com/itm/Alfa-Romeo-Be...57?_mwBanner=1
getv2000 is offline
post #10 of 17 (permalink) Old 10-27-2017, 04:32 AM
Tom Frasca's Avatar
Yes they do, castor arms are already adjustable the stock upper control arms are fixed if you replace them with the GTA style upper control arms you can also adjust camber ...
post #11 of 17 (permalink) Old 10-27-2017, 05:34 AM
bellagt's Avatar
Your desired tire will dictate the ride quality and charachteristics you want from your car. If you want to retain the original light, nimble feel, with a vintage look, then a 185/70/14 or even a 165 will give you that. If you prefer more road holding, and a more aggressive look, then a 195 or even 205 will accomplish that at the expense of a heavier and harsher ride.
Tom Frasca and getv2000 like this.
bellagt is offline
post #12 of 17 (permalink) Old 10-27-2017, 05:55 AM
gigem75's Avatar
If your car is straight there is not much to be gained from upper adjustable control arms. The become worth it when lower springs are installed and allow camber to be set back to where the Alfa engineers originally wanted it. If this is your first Alfa note that with any wider tire you don't want to steer the wheels when the car is stationary. Many a cracked steering box has happened by just that. I don't have any intelligent tire choices
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #13 of 17 (permalink) Old 10-27-2017, 07:30 AM
Tom Frasca's Avatar
But the way the price for a set from Alfaholics is about $220. the ebay Item is a ripoff.
https://www.alfaholics.com/parts/105...arm-left/?USD#
post #14 of 17 (permalink) Old 10-27-2017, 07:46 AM Thread Starter
getv2000's Avatar
Thanks for sharing! Will keep it in mind.
getv2000 is offline
post #15 of 17 (permalink) Old 10-27-2017, 07:54 AM
Tom Frasca's Avatar
I by almost all my parts from them, I am in New York, if I call them before 10A.M London time the parts usually are at my home the next day...except for bulky Items such as a set of rims took 3 days...shipping charges are very reasonable... quality is outstanding.. not a plug for one vendor over another Just my personal experience...
