1750 project! - Page 3 - Alfa Romeo Bulletin Board & Forums
 7Likes
post #31 of 50 (permalink) Old 09-17-2018, 06:10 AM
RicksAlfas's Avatar
Sounds like you have it all under control!
I like the grab bag hanging from the rafters. Is that in case the missis finds out how much it's all going to cost and you have to make a run for it?
Have you attempted to take the door glass out yet?
I can't fathom mine out...
https://www.alfabb.com/bb/forums/gt-...ml#post8316282
1750 GTV Mark 1
RicksAlfas is offline
post #32 of 50 (permalink) Old 09-17-2018, 10:14 AM Thread Starter
Lawso's Avatar
Not got round to stripping the doors out yet, I just wanted them off in preparation for welding the sills etc. So you can give me the heads -up once you’ve done yours😁
Lawso is offline
post #33 of 50 (permalink) Old 09-17-2018, 02:36 PM
PSk
Are you replacing the guard(s) and nose panel? ...
'71 1750 Series 2 GTV:
PSk is offline
post #34 of 50 (permalink) Old 09-17-2018, 11:55 PM
RicksAlfas's Avatar
Good point well put. Will do.
1750 GTV Mark 1
post #35 of 50 (permalink) Old 09-17-2018, 11:59 PM Thread Starter
Lawso's Avatar
Hmmm, I probably will replace them, the wings/fenders need the usual repair panels and then some, the front panel is damaged and corroded above the repair panel cut off line. I think by the time I’ve bought the repair sections, fabricated other minor repairs + time to do them, it may work out better just to get replacement complete panels. I’m not sure of the quality and fit of replacement panels though, they too might take some work to get a good fit.
Lawso is offline
post #36 of 50 (permalink) Old 09-20-2018, 12:20 AM
RicksAlfas's Avatar
I've done them! I've updated the thread linked above. Let's just say I'm glad I don't have a Super or Berlina.
1750 GTV Mark 1
post #37 of 50 (permalink) Old 09-20-2018, 02:03 AM
I took a similar approach with my Duetto.
Completely removed the front clip exposing the inner wings, rad support etc (all replaced with new).
Completely removed the rear clip and transom exposing the inner arches and superstructure. All sills both sides (inner, middle, outer). Rebuilt the rear parcel shelf floor as new (3 layer construction). New floors, panels fitted as factory where possible or remade if unobtainable and then fitted as factory.
Saved an inordinate amount of time as we just disassembled the body and refitted panels as they did originally. Amazing how little primer there was on inner surfaces. The rear inner arches under the rear ‘fender’ was unpainted bare bright steel (still, amazingly).
It’s quite surreal to see the car without any outer panels. Even more surreal to know it’s now rust free and better protected than most new cars
Best of luck!!
Craig_m67 is offline
post #38 of 50 (permalink) Old 09-20-2018, 11:47 AM
PSk
I'm no expert, but I think it would be wise to buy the new panels first so you can then ensure you are removing the old panels at the correct place ...
(And yes if I ever do another 105, I think I'll remove the whole front clip to repair and reinstall because then you can get to both sides of the outer panels everywhere. Same could be done with the rear ... keeping guards and rear panel as one assembly. Live and learn )
Best
PSk is offline
post #39 of 50 (permalink) Old 09-20-2018, 01:05 PM
As you will be hanging your doors many times to check your new sills it is wise to remove the door from the hinges, and leave those in place on the body, so you have a good reference point to start rebuilding the front and rear.. It's very easy to just start and keep removing steel, but it's better to keep some true points.
From experience..
Best,
JC
JC de Koeijer
Giulia street rod, '65 Giulia 1600Ti, 74 Spider Veloce, '05 GT.
JCDK is offline
post #40 of 50 (permalink) Old 09-20-2018, 02:11 PM Thread Starter
Lawso's Avatar
You can’t beat advise based on experience, please keep it coming. Not only will I be referring to my notes and photos during the course of the restoration but also this forum, in fact mainly this forum. So I take all advise gratefully. I’ve removed the front guards by drilling out the original spot welds, however I made the cut from the front panel (clip) a little further forward as the front panel won’t be reused(well it’s unlikely) but I may re-use the guards.
Lawso is offline
post #41 of 50 (permalink) Old 07-09-2019, 11:35 AM Thread Starter
Lawso's Avatar
So after what feels like forever I made a start cutting out rusted metal today, I’m starting on the o/s sills. First I cut out the outer sill and took photos of the original welds/fitment of the middle sill(well what was left) then cut out the middle sill and took plenty photos of the welds/fitment of the inner sill, then off came the inner sill. Extremely apprehensive to begin with but with each cut the nerves eased. Just getting rid of a lump of rusty metal makes it feel better already. Last photo shows inside of the outer sill, note how the top half is solid along most of it.
PSk likes this.
Lawso is offline
post #42 of 50 (permalink) Old 07-16-2019, 04:29 AM Thread Starter
Lawso's Avatar
Before fitting the new inner sill I had to address the corrosion on the front inner arch panel , this in turn led to addressing corrosion higher up and into the bulkhead corner and scuttle area. Each repair needed to attach to a panel that needed repaired itself!! So I’ve got my first repair panel made and welded in, excuse any imperfections, this ain’t going to be a concourse job but just as good as I can make it look to original within my capabilities.
Lawso is offline
post #43 of 50 (permalink) Old 07-16-2019, 07:43 AM Thread Starter
Lawso's Avatar
Top repair panel done now. Just got the A post panel flange to repair to the arch panel then the inner sill can go in. Even though there’s still so much to do I feel like I’ve achieved my first milestone...making a start!
PSK... your advice in an earlier post was perfect “it’s just metal” and “practice”. I’d talked myself out of doing it for months, now I feel I’ll get it done in no time!😬👍
Ranz and BigMart like this.
Lawso is offline
post #44 of 50 (permalink) Old 07-16-2019, 11:33 AM
PSk
Great work
PSk is offline
post #45 of 50 (permalink) Old 07-17-2019, 03:32 AM
BigMart's Avatar
Making good progress Lawso! Cracking work so far.
Don't be too daunted by it all. The road to restoration is to think of it as just lots and lots of small jobs, rather than one big job!
I don't focus on finishing the project, just on each small piece of it...and then try to enjoy each piece.
If motivation wanes then just walk away for a few weeks...and come back refreshed.
And don't set timescales
Im enjoying the journey and gaining satisfaction at gaining new skills (and tools!)
If you need anything just ask
1972 GT 1600 Junior
At the very start of a long restoration road....
BigMart is offline
