The missing link story.... - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 2 Post By tuttebenne
  • 1 Post By Alfajay
post #1 of 14 (permalink) Old 02-24-2017, 06:15 PM Thread Starter
kitora's Avatar
Had to pull the head off my 1300 junior to fix an issue with a valve. I was putting it back on the car today, and the worst thing happened: I dropped the cam chain link into the engine!
I have taken the oil sump cover off and have spent 3-4 hours with magnets and air pressure trying to find the link, but it is nowhere to be found. I am suspecting (or hoping) that I have dropped it somewhere and that it is no longer in the engine. However I am not sure that is a 100% the case.
I am totally out of ideas on how to find it, as I just keep repeating what I have now done for several hours. Any great ideas out there?
I know that it could cause a fatal engine error if I just put the engine back together and run it, but I don't know what to do. What would my fellow alfaBB'ers do?
1974 Alfa GT1300Junior
kitora is offline
post #2 of 14 (permalink) Old 02-24-2017, 08:40 PM
rogerspeed's Avatar
install another timing chain link, rotate the engine by hand, if it goes twice no problem, if it binds the missing link is in the chain, as you haven't fired the motor, un-torque the head and carefully remove the timing cover
current:
84 Spider Veloce
ex:
rogerspeed is offline
post #3 of 14 (permalink) Old 02-24-2017, 11:00 PM Thread Starter
kitora's Avatar
I took the chain out completely when it had happened, and my search was without a chain in the engine, but still with no luck. I have rotated the engine multiple times between blowing air to see if the d*mn thing was stuck somewhere and came loose with the air preasure. The engine turns nicely without any indication of a chain link stuck anywhere.
How can something like that just disappear? Bermuda traingle engine... ?!
Anyways, if anyone in the Bay Area happens to have a spare chain link, I am very interested in buying from you this weekend.
kitora is offline
post #4 of 14 (permalink) Old 02-24-2017, 11:45 PM
rogerspeed's Avatar
it probably isn't in there, though the lower chain can't be visually inspected (or removed) with the timing cover in place. You could rent/borrow a borescope.
current:
84 Spider Veloce
ex:
post #5 of 14 (permalink) Old 02-25-2017, 01:03 PM
Got a smart phone? Pick up one of these
https://www.amazon.com/SanSiDo-Megap.../dp/B01IA15YG0
My kids got me one for Christmas and there isn't a hidden space that is safe from me any more. It even comes with a small attachment that goes on the end of the camera containing a magnet - to retrieve small metallic items such as your missing link.
These are just too cheap now for us all to not have one (no affiliation with these things)
cuorealfa and f4driver like this.
tuttebenne is offline
post #6 of 14 (permalink) Old 02-25-2017, 03:26 PM
gigem75's Avatar
What part of the link did you drop? The big one with the pins or just the clip or one of the two links? I assume you have removed the camshafts when rotating the bottom end? I know this sounds crazy but since you have the bottom off the sump you can drop another piece down and watch where it goes, it might lead you to the missing piece.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #7 of 14 (permalink) Old 02-26-2017, 12:45 PM
Its not such a crazy idea because there is a link down there already and it needs to come out anyway.
Many moons ago I was a computer tech and lost a coil spring holding a Disc drive door interlock (these were the days when drives were the size of a washing machine.) There was a spring and interlock on the left and one on the right. I had lost the right one. If I had to go back to the office to source another spring, the customer would have been down the entire time. So what did I have to lose? I launched the spring from the left side at the same point on the right where the other had flown off. Low and behold, it hit the floor about ten feet away and rolled under a cabinet in the office and right next to it was the other one! Zero to hero!
post #8 of 14 (permalink) Old 02-26-2017, 01:13 PM Thread Starter
kitora's Avatar
I gave up on finding it and bought a new link. The engine is now running again, and I am crossing my fingers that it shows up on my garage floor and not somewhere where it is not supposed to be in the engine. It was the large part with the pins that I lost.
kitora is offline
post #9 of 14 (permalink) Old 02-26-2017, 02:09 PM
ECARRILLO's Avatar
Did you check the oil plug? Maybe it's stuck at the magnet.
Eliseo Carrillo
105.30....Scalino
101.23....Little Green Spider - now back home with Dr. Rex
ECARRILLO is offline
post #10 of 14 (permalink) Old 02-26-2017, 06:33 PM Thread Starter
kitora's Avatar
Nope, wasn't there.
kitora is offline
post #11 of 14 (permalink) Old 02-26-2017, 06:57 PM
Alfajay's Avatar
Oh, it's probably in the sump. But it won't cause any harm - the oil will keep it from bouncing up into the spinning crankshaft or chains, and the oil pump has a screen to prevent it from getting ingested. Just don't worry about it. Nine oil changes down the road, it will show up on the drain plug magnet.
cuorealfa likes this.
Alfajay is offline
post #12 of 14 (permalink) Old 02-28-2017, 06:56 AM Thread Starter
kitora's Avatar
It wasn't in the sump. I pulled the lower sump cover off and inspected/searched from below as well as from above.
My conclusion is that it magically disolved itself as it dropped into the engine, and I will never see it again....
kitora is offline
post #13 of 14 (permalink) Old 02-28-2017, 09:22 AM
ECARRILLO's Avatar
Wink
Hope it let's you sleep........
Eliseo Carrillo
105.30....Scalino
post #14 of 14 (permalink) Old 02-28-2017, 09:35 AM
Alfajay's Avatar
By "the lower sump cover" I assume you mean that "D" -shaped part at the very bottom of a 105 oil pan. There are a lot of places for a small part to hide above the lower sump cover. The upper part of the sump has some ridges and oil is sticky enough to keep the link from dropping to the lowest point in the sump.
But the "magically dissolved itself" explanation works for me too!
Alfajay is offline
