GTV Flasher Circuit - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 04-05-2016, 10:18 AM Thread Starter
BostonBertone's Avatar
GTV Flasher Circuit
I'm expecting I will need flashers to pass MA inspection. Below are my thoughts based on a bit of research here. My goals are to not cut into any stock wiring or mess with the stock appearance.
I'll add 3 new wires into the existing circuits using piggy back terminal connectors. There will be no cutting or use of splice connectors.
For example the terminal 49a of the flasher I can plug in a new jumper to my hazard switch and use the piggy back to connect the stock black connector to the existing turn signal switch.
In the same manner I can run the other side of my hazard switch to each turn signal circuit via the positive indicator lamp connections. Again i will use the piggy back to handle the stock indicator feeds. Two diodes will ensure that when the normal turn signal is switched it doesn't back feed through my hazard switch and run both left and right sides.
The SPST switch will be located in an accessible place but not cutting into my restored dash. Its a simple covered toggle to avoid inadvertent use. Seem solid?
68' Parisian Alfa GTV 1750
BostonBertone is offline
post #2 of 6 (permalink) Old 04-05-2016, 03:55 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
British wiring has the real deal spade terminals.
ossodiseppia is offline
post #3 of 6 (permalink) Old 04-05-2016, 05:23 PM
Alfajay's Avatar
Originally Posted by BostonBertone View Post
Seem solid?
Yes, your circuit should work just fine.
Note that if you use a double pole switch, you can eliminate the need for the diodes. The signal from flasher pole 49a would go to one pair of terminals on the DP switch, while the leads to the L and R lights go to the mating pair.
It is interesting that Massachusetts requires flashers on a car that was not built with them originally. Why flashers but not airbags and anti-lock brakes?
But hey - adding flashers is easy and they are worth having.
Alfajay is online now
post #4 of 6 (permalink) Old 04-05-2016, 06:58 PM Thread Starter
Simpler yet. I like it.
They may not require it - I'll see. I am preparing and agree they are good to have. My car also has the yellow headlights of France pre 1994 and that won't meet the two white front facing light requirement. So I swapped the outers. I'll keep the yellows for posterity.
post #5 of 6 (permalink) Old 04-05-2016, 06:59 PM Thread Starter
Nice. There is something about the colored crimp connectors that seem cheap. I like the regular ones with heat shrink.
post #6 of 6 (permalink) Old 10-05-2019, 07:28 PM
bfeng's Avatar
I know this is a very old thread, but MA does not require flashers on cars that didn't come with the originally.
I have a 1964 and a 1954 car, neither of which has emergency flashers, just turn signals.
I've been told each year when I get my inspection that it's fine as long as the car wasn't originally equipped with emergency flashers.
John F.
bfeng is offline
