Seat belts and Hand Brake light - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 17 (permalink) Old 09-30-2016, 11:13 PM
1972-GTV's Avatar
I pulled the orange wire...
Originally Posted by bellagt View Post
Some on the BB have recommended "Wesco" seat belts. Use the Search function with that key word and some threads will pop up.
If you're brake warning light is on and all seems to be working ok, it could be a stuck brake pressure light switch. Pop open the hood and just to the rear of the SPICA fuel filter, on the passenger side of the engine bay, you'll find some hard tubing that is screwed into a small black manifold. At the top center of that manifold is a switch with an orange wire. Pull the wire from the switch to create an open circuit and see if the brake light goes out. If it does, the switch is stuck in the closed position.
I have the same problem with my brake dash light always on...I pulled the orange wire and the light went out. Is it possible to fix it so it isn't stuck in the closed position?
Dennis
1972 GTV (registered as 1973)
1972-GTV is offline
post #17 of 17 (permalink) Old 10-01-2016, 10:38 AM
bellagt's Avatar
It can't hurt to pull, inspect and shoot it with some brake cleaner fluid... Rap it hard for good measure and reinstall it... Then bleed the brakes since you'll likely introduce air into the system.
Ken
'73 GTV
bellagt is offline
