door topper - Alfa Romeo Bulletin Board & Forums
post #1 of 16 (permalink) Old 02-08-2016, 06:14 PM Thread Starter
door topper
Larry the APE man calles the chrome strip on the insdie and outside of the doors on our coupes "door toppers."
On a 105 coupe there is a horizontal piece of chrome trim at the top/outside of the door that holds the felt window wipe in place. At the bottom edge of that piece of trim there is a black piece of plastic trim. It is long and narrow and it lays on the bottom edge the chrome next to the paint. I know y'all know what I am talkin about. Where can I find a couple of those do-dahs?
dlbehrns is offline
post #2 of 16 (permalink) Old 02-08-2016, 07:30 PM
bellagt's Avatar
That do-dad is pretty much unobtanium. The factory trim has a very low outer profile and a taller inside profile. I think you many need to settle for the lowest profile U-channel rubber edge trim that you can find. It's not uncommon to see restored GTVs with this generic edge trim.
Ken
'73 GTV
bellagt is offline
post #3 of 16 (permalink) Old 02-08-2016, 07:34 PM Thread Starter
I can go with generic edge trim but where can I find it? TIA, DB
dlbehrns is offline
post #4 of 16 (permalink) Old 02-08-2016, 07:37 PM
bellagt's Avatar
Google and eBay are your friend...
Ken
'73 GTV
bellagt is offline
post #5 of 16 (permalink) Old 02-08-2016, 07:39 PM Thread Starter
That is what I am looking at now. Have you ordered any b 4 and if so what measurement comes close to the original? TIA
dlbehrns is offline
post #6 of 16 (permalink) Old 02-08-2016, 07:40 PM
bellagt's Avatar
I have the original do-dads on my GTV... the outside edge is barely a lip... get the lowest profile you can get...
Ken
'73 GTV
bellagt is offline
post #7 of 16 (permalink) Old 02-08-2016, 08:03 PM Thread Starter
Just went w/ 1 32" Rubber Edge Trim HR 71A Sold by The Foot 1 32 x 3 16 U Channel EPDM | eBay
Should work. Thanks bellgat!!!!!!!!!!!!!!
dlbehrns is offline
post #8 of 16 (permalink) Old 02-08-2016, 08:23 PM
Ranz's Avatar
And if you're not happy with it, I am sure I have seen it on one of the UK suppliers' sites. Cheap as chips. I usually haunt Highwood, Classic Alfa & Alfaholics. Try those in that order.
Ranz is offline
post #9 of 16 (permalink) Old 02-09-2016, 08:56 AM Thread Starter
Classic doesn't have it. Will check Alfaholics. thanks!
dlbehrns is offline
post #10 of 16 (permalink) Old 02-09-2016, 11:02 AM
Ranz's Avatar
I checked Highwoodalfa again. They definitely have it. I also found the length I bought a while ago.
Ranz is offline
post #11 of 16 (permalink) Old 02-09-2016, 11:42 AM
bellagt's Avatar
Good to know it is available. It's a little detail that many don't get right when restoring their cars.
Ken
'73 GTV
bellagt is offline
post #12 of 16 (permalink) Old 02-09-2016, 11:50 AM
Would that be item 6181 on the Highwoodalfa site?
Just to be sure for my sake, is that the piece that looks like it is crimped every so often along the inside of the chrome trim piece?
5thinline is offline
post #13 of 16 (permalink) Old 02-09-2016, 12:11 PM Thread Starter
Classic
This is what I found at Classic Thin rubber seal - per metre
Has anyone used this for the door trim which is other than their application for the spyder grill piece?
dlbehrns is offline
post #14 of 16 (permalink) Old 02-09-2016, 12:17 PM
bellagt's Avatar
Yes, Highwood's 6181 appears to be the correct trim that is run on the lower edging of the chrome trim along the door and rear quarter windows. But it is not crimped. It's just held in place by the chrome trim itself when the trim is screwed to the body. And I believe it was only used on later GTVs (2000 for sure, maybe 1750).
Ken
'73 GTV
bellagt is offline
post #15 of 16 (permalink) Old 02-09-2016, 01:16 PM Thread Starter
order?
I'm looking at the Highwood site and I will be dammed if I can figure out how to search for a part # of place an order. I'm really not puter illiterate. FWIW I found it but, this is not an easy site to navigate, eh.
dlbehrns is offline
