Bare Metal Rebuild Phase III: Reassembly - Page 22 - Alfa Romeo Bulletin Board & Forums
 114Likes
post #316 of 425 (permalink) Old 02-25-2018, 11:03 AM Thread Starter
r-mm's Avatar
Thanks to two kind and car-obsessed neighbors (their fleet includes two NSXs a LS powered RSX and a '66 Chevelle SS 396) we got the front glass installed in about 90 seconds. Maybe less. Easy when you know how!
PSk, cucinando and cuorealfa like this.
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
post #317 of 425 (permalink) Old 02-25-2018, 01:39 PM
Yachtman's Avatar
I knew you could do it!!
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #318 of 425 (permalink) Old 03-04-2018, 01:05 PM Thread Starter
r-mm's Avatar
How good is the fit of the seal on the perimeter of the splash guards to the body on your cars? I believe the rear of the front wheel well splashguard is a somewhat important part of corrosion control? I have waxoyle that cavity back there but don't want to invite problems. I am using aluminum replacement splash guards from one of the European suppliers I can't remember which.
r-mm is offline
post #319 of 425 (permalink) Old 03-08-2018, 04:06 AM Thread Starter
r-mm's Avatar
Huh, did the factory use rivets to attach these panels? I have mine all in place now, using SS sheet metal screws. Seems like maintaining future access isn't a terrible idea (check for small animals, corrosion).
r-mm is offline
post #320 of 425 (permalink) Old 03-08-2018, 06:55 AM
In terms of real world practicality, yes, retain the panels with screws, unless you never drive through mud and never anticipate having to replace a side marker light.
This juncture of sheet metal pieces is well known as a spot to foster corrosion brought about by leaves, mud, etc. collecting at the bottom. I've had an AMHIK experience in this matter.
Do yourself a favor and make sure there is ample room for drainage. I make sure it is clear every time I wash the car, and I don't drive in the rain or on dirt roads with it.
Capp is offline
post #321 of 425 (permalink) Old 03-08-2018, 09:33 AM
PSk
We are talking about Alfa Romeo here, these parts did not make the car go faster or handle better ... so little effort was put into them
'71 1750 Series 2 GTV:
PSk is offline
post #322 of 425 (permalink) Old 03-08-2018, 09:40 AM Thread Starter
r-mm's Avatar
Ha - fair enough. I whack/bang/bent these into shape and now recommend the alum replacements quite highly. Very easy to fettle, will not rust, added lightness!
I thoroughly waxoyl'd the area to the rear of the wheel and will give it a look every now and then.
r-mm is offline
post #323 of 425 (permalink) Old 03-08-2018, 09:48 AM
PSk
Can you weld aluminium?, might be a good idea (now that we are not only worried about performance) to add some to the shape to make them fit better?
Yachtman likes this.
PSk is offline
post #324 of 425 (permalink) Old 03-08-2018, 10:12 AM Thread Starter
r-mm's Avatar
Can I ? I can not. Well I take that back I probably remember how to but don't have access to a TIG anymore.
If anything I think the best mod would be removing the rubber portion (it's stapled), adding a longer more flexible profile and then trimming that where it can't be compressed to fit.
r-mm is offline
post #325 of 425 (permalink) Old 03-08-2018, 12:00 PM
I took mine off last spring and so I got a good look at how they were originally fitted. My Super is very original and the splash guard area had obviously never been touched. The fit of the flash guard was much closer than yours, I'm afraid, and was held in place with sheet-metal screws. As I recall, there was no evidence of sealant on the rubber gasket nor was there any evidence of moisture, dirt, or rust in this critical area. So the flush fit was obviously critical. When I put it back on, I used some additional sheet-metal screws just to be on the safe side. The fit was again uniformly flush, however.
Taking the splash guard off was a pretty interesting experience in itself because I found myself looking at an inner panel that had been sealed for 45 years. The inner fender had been painted body color and so I was surprised at how my compounding efforts had restored the 45 year old outsides to very closely match the original color that I found in the sealed panel. This is a testament to the quality of Alfa's single-stage enamel paint.
Re: Inside plastic door sheets. I abandoned trying to attach these with any kind of glue which I found messy and gave me less confidence that it would actually keep water out of my car. Instead, I switched to using duct-tape to seal the plastic sheet edges to the door sheet-metal. This is remarkably easy to do, is waterproof, and and can easily be removed when you need to do so.
cucinando likes this.
180OUT is offline
post #326 of 425 (permalink) Old 03-10-2018, 04:02 PM Thread Starter
r-mm's Avatar
Anyone have an extra cowl grommet or know of w source?
r-mm is offline
post #327 of 425 (permalink) Old 03-13-2018, 08:16 AM Thread Starter
r-mm's Avatar
Getting somewhere...
PSk, Capp, 1750GT and 2 others like this.
r-mm is offline
post #328 of 425 (permalink) Old 03-13-2018, 09:08 PM
Yachtman's Avatar
And a fine looking place it is 😃😃
1969 GT 1300 JR
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #329 of 425 (permalink) Old 03-15-2018, 03:00 PM
AlessandroM's Avatar
Have you completely rewired the lights via relays?
I'm thinking about doing that as well but I would have preferred to keep them inside the cabin, but I aint sure how to get the cable to the front the same route where they were before.
Learning, learning..
AlessandroM is offline
post #330 of 425 (permalink) Old 03-15-2018, 03:13 PM Thread Starter
r-mm's Avatar
Yup. My battery is in the rear so I bring the main B+ to the starter, then an 8ga (I think, can't recall) to the new 4 position fuse box and another 8ga from there to the alternator.
r-mm is offline
