Synthetic transmission oil ? - Alfa Romeo Bulletin Board & Forums
post #1 of 17 (permalink) Old 05-25-2015, 10:15 PM Thread Starter
arties68gtv's Avatar
Well after pulling the transmission and installing new bearings and bushings I still can hear a whine coming from gear box. the noise goes away totally when clutch peddle is activated. The mechanic said all Alfa transmission have a whine to them, my dad has a Giulia Super and I dont hear the transmission at all. I was wondering if the syncro rings in my transmission can handle a synthetic tranny oil? As this my help reduce the noise...
arties68gtv is offline
post #2 of 17 (permalink) Old 05-26-2015, 07:42 AM
Gubi's Avatar
Did you replace the rubber shift boot(s)? If those aren't in good condition you get a LOT of noise from the gearbox, even if it's in good shape.
Redline 75W90NS is synthetic and appropriate for your GTV. While it reportedly works very well for shifting, I doubt it's going to make a lick of difference with regards to noise, though. If you try it make sure you get the stuff with the NS in the name.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #3 of 17 (permalink) Old 05-26-2015, 07:43 AM
Hi,
synthetic transmission oil has no influence on such NVH issues, only increased viscosity may help.
The root cause of whining is usually gear wear.
BTW synthetic oil will definitely ruin your synchro rings as the contained sulphur and phosphor destroy the coating.
Saluti
Ribolla
ribolla is offline
post #4 of 17 (permalink) Old 05-26-2015, 09:45 AM
Gubi's Avatar
Agh...no...
Alfa transmissions built after 19-sixty-whatever are designed for EP gear oils. Alfa spec'd GL5 gear oil, and the sulfur EP compounds in it are fine for later Alfa transmissions.
Sulfur, phosphorus, and EP additives have NOTHING to do with whether the base oil is synthetic or not.
1974 GTV
1991 Spider
Gubi is offline
post #5 of 17 (permalink) Old 05-26-2015, 10:44 AM
"the noise goes away totally when clutch peddle is activated" If the car is in neutral with the clutch in then none of the trnsmsm parts are moving, then I would find it difficult to blame the transmission or synthetic oil. And I agree(cuz I've read mountains of posts on the synthetic oil issue)Synthetic is just fine. Its probably your throw out bearing that is making the noise.
dlbehrns is offline
post #6 of 17 (permalink) Old 05-26-2015, 01:11 PM
brad fischer's Avatar
But when you put your foot on the clutch pedal the throw out bearing is loaded up and spins at engine speed. The pilot bushing will also be spinning relative to input shaft.
brad fischer is offline
post #7 of 17 (permalink) Old 05-26-2015, 04:19 PM
sounds to me like a throw out bearing- Theory <I think> the bearing spins in a no load state when the clutch pedal is released creating a whine due to a free spinning bearing. Pushing the clutch pedal puts the bearing into a load condition which then quiets the bearing due to the load.
As with all things forum, happy to be corrected by those with greater knowledge
willwiser is offline
post #8 of 17 (permalink) Old 05-26-2015, 05:46 PM
Depends if the throw out is in constant contact even when no pressure is on pedal, or there is free play IE clearance between pressure plate fingers and throw out bearing. I assume hydraulic clutch is in constant contact and mechanical clutch linkage would have free play.
post #9 of 17 (permalink) Old 05-26-2015, 05:59 PM
Push hard and live
DPeterson3's Avatar
Generally....
Spring-type pressure plates (1600, and earlier) require some clearance between the TO bearing and the pressure plate fingers. Diaphragm types (1750 and later) have the TO bearing in constant contact with the multiple thin fingers of the diaphragm. I can't tell from the original post what type of clutch/TO the writer has. Leaving a spring-type TO in constant contact with the pressure plate without clearance might well lead to a whining when the box is in neutral and the car is stopped with minimum engine noise.
My current box in my 2000 (a modified 2600 box) has some whine, due to a worn input shaft gear. The input shafts for these boxes are hard to get, so we used the best we had. In neutral, with the foot off the clutch pedal, the input shaft will be turning, along with the first gear on the lay-shaft. Worn teeth will be heard as whining.
I have read on the BB that the Redline NS is great for all Alfa transmissions. I still have a couple of gallons of Dentax and plan to use it in my 2000 (1959) trans until it's used up, then perhaps try the NS.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #10 of 17 (permalink) Old 05-26-2015, 07:31 PM Thread Starter
The guy who rebuilt the tranny did say there was wear on the input shaft gear.... i have disconnected the linkage to the clutch fork and it still whines... I have installed new clutch kit so throw out bearing is brand new.... It must be the wear on the input shaft gear. I have installed all new boots on top of tranny... guess Iam gonna have to live with it... as a new rebuilt tranny is not in the budget this year, plus there hard to come by. thanks to all for your input..
post #11 of 17 (permalink) Old 05-26-2015, 07:43 PM
Back to my point: fluid in and of itself is not going to cause a transmission that is not turning to whine.
dlbehrns is offline
post #12 of 17 (permalink) Old 05-26-2015, 09:50 PM Thread Starter
When the clutch peddle is activated and car is in neutral the sound disappears as the transmission is disengaged and is not turning. Release the clutch peddle and its back and the whine increase with engine RPMs ... Wouldnt the throw out bearing make a noise only when clutch peddle is pushed.?
post #13 of 17 (permalink) Old 05-27-2015, 09:41 AM
Richard Jemison
Alfar7's Avatar
Noise
Whine is typically gear mesh issue. Roaring noise bearing issue.
I suggest you order 2 quarts of Redline 75-140 NS and fill trans with that.
NOTE Redline 75-90 NS is best for typical Alfa use. The 75-140 NS is more viscous and should quieten gear to gear interface noises. ONLY NS, No other gear oil.
However the only other oil I would consider would be a GL3 or GL4 90-140 wt gear lube. These oils will likely cause syncro issues due to being too slipery/thick for proper baulk ring syncro design.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is online now
post #14 of 17 (permalink) Old 05-28-2015, 07:43 AM Thread Starter
Thanks Richard ...Iam gonna give that a try Ill let you know how it works...Arthur
post #15 of 17 (permalink) Old 06-02-2015, 06:39 PM Thread Starter
Well I never got a chance to try that transmission oil . I insured car and drove it three blocks when I went to shift to four gear the friggin tranny locked up solid.. The rear tires locked up and I skidded around till I got her on the shoulder of the road... I think that the shift forks must have been installed wrong and it pulled two gears at same time... iam so disappointed as this is the third time I've had that tranny apart...I'am on suicide watch ....lol
