GT 1600 Junior project begins! - Page 30 - Alfa Romeo Bulletin Board & Forums
 100Likes
post #436 of 465 (permalink) Old 06-04-2019, 02:35 PM
Sketchl's Avatar
Great work Bigmart.
This is from a 66’ which should be the same and trust that someone with the same model as yours can confirm!
1966 Giulia Sprint GT Veloce - slightly modified!
Sketchl is offline
post #437 of 465 (permalink) Old 06-04-2019, 04:07 PM Thread Starter
BigMart's Avatar
Originally Posted by Sketchl View Post
Great work Bigmart.
Cool thanks
I thought there might be a horizontal seam, and it looks like there is indeed!
1972 GT 1600 Junior
At the very start of a long restoration road....
BigMart is offline
post #438 of 465 (permalink) Old 06-06-2019, 11:00 AM
Subscribe
Love your post. Started binge reading yesterday.
Kim Boydell is offline
post #439 of 465 (permalink) Old 06-06-2019, 02:08 PM Thread Starter
BigMart's Avatar
Originally Posted by Kim Boydell View Post
Subscribe
Thanks 🤓
You can take a break from me for a week or so as I’m off on holiday now 😀
Schuey likes this.
1972 GT 1600 Junior
BigMart is offline
post #440 of 465 (permalink) Old 06-17-2019, 01:11 PM Thread Starter
BigMart's Avatar
Had a spare hour this evening and was itching to get back into the workshop after a nice relaxing holiday, so started to make a part for the upper a-pillar.
I am folding and curving the inner strip and rain channel section. I’m doing this prior to cutting the old one out - so I can use it as a reference.
I folded the sheet steel up with a hobby vice mounted folder, which is ok but doesn’t give a sharp fold (more of a radius than a sharp 90degrees) so had to hammer it sharper against a square bar to get something more like the original part.
Then fired up the shrinker/stretcher to form the curve. We are about 90percent there - needs some tweaking still to get radius of curve perfect.
Here is progress so far
1972 GT 1600 Junior
BigMart is offline
post #441 of 465 (permalink) Old 06-29-2019, 09:16 AM Thread Starter
BigMart's Avatar
Today’s job was to delve into the upper a-pillar - I include photos of the internal pieces to show how it’s put together. It’s not done very often so thought a good idea to show its construction.
Actually once stripped things weren’t terrible-but I decided to re-make the inner gusset rather than de-rust it, as not a complex piece. See below stages of stripping out, cleaning.
1972 GT 1600 Junior
BigMart is offline
post #442 of 465 (permalink) Old 06-29-2019, 09:21 AM Thread Starter
BigMart's Avatar
Remade inner gusset piece, and fettled rain channel section. Also epoxy primed the inner piece - ready for welding up tomorrow.
1972 GT 1600 Junior
BigMart is offline
post #443 of 465 (permalink) Old 06-29-2019, 03:58 PM Thread Starter
BigMart's Avatar
Ready to weld up
Nakagtv likes this.
1972 GT 1600 Junior
BigMart is offline
post #444 of 465 (permalink) Old 06-29-2019, 06:12 PM
PSk
Nice work
'71 1750 Series 2 GTV:
PSk is offline
post #445 of 465 (permalink) Old 06-29-2019, 11:50 PM
Home Built by J's Avatar
Looking good.
Backyard hack car builder with a YouTube channel
youtube.com/homebuiltbyjeff
Home Built by J is offline
post #446 of 465 (permalink) Old 06-30-2019, 04:49 AM Thread Starter
BigMart's Avatar
And welded in.
Next up is the tricky bit....making the outer part. 🤔
1972 GT 1600 Junior
BigMart is offline
post #447 of 465 (permalink) Old 07-01-2019, 03:27 AM Thread Starter
BigMart's Avatar
Points to note:
1. Epoxy priming before welding up is a waste of time in such small areas. I ground off the primer at the location of the plug welds (say about 1" square and coated with weld thru primer) but the heat from welding just burnt off all primer in th local area (or it caught light) so left with almost zero primer intact!. So won’t do that again!
2. I learned that my spot welder works great, but you really need to have clean metal surfaces to weld together/through. I linished the metal on each side of metal pieces being welded together, as im using zinc coated sheet steel (zintec). Doing this meant the welder worker a charm. Image above shows the inner gusset spot welded to the rain channel section. Using spot welder before I found it a bit temperamental. Lesson learned
1972 GT 1600 Junior
BigMart is offline
post #448 of 465 (permalink) Old 07-01-2019, 04:37 AM
gigem75's Avatar
Way cool! That one curve of the sheetmetal in front of the A pillar is where it would be better than great if there was replacement metal available. It really is a long and winding restoration road.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #449 of 465 (permalink) Old 07-01-2019, 04:49 AM Thread Starter
BigMart's Avatar
Yes indeed.
I will take some pictures of my attempts to remake it! 😀 Might be helpful to others.
1972 GT 1600 Junior
BigMart is offline
post #450 of 465 (permalink) Old 07-06-2019, 10:08 AM Thread Starter
BigMart's Avatar
Fabricated up the outer panel.
Slit the lower end and used Shrinker to get a curve. Also put a slit in the wing to allow to curve that up a bit as it was a bit flatter than it needed to be. Needed a bit of hammer dolly work to form 100%
Home Built by J likes this.
1972 GT 1600 Junior
BigMart is offline
