AFrench Blue '69 GTV Restoration - Page 96 - Alfa Romeo Bulletin Board & Forums
 218Likes
post #1426 of 1592 (permalink) Old 08-28-2018, 05:59 AM
The shift gaiter looks forlorn.... ;-)
Originally Posted by 1750GT View Post
Update time....I spent the past 4 or so weekends working on the wheels. I starting off with having them stripped and acid dipped at Technostrip....saved me a ton of time.....so I thought. Problem was that because I wasn't able to get to them till a few weeks later (due to work obligations) ....the nicely bare metal developed a lot of flash rusting with some acid bleed- out of the joints between the centre and outer ring joints (sorry no photos taken)...I expended a lot of effort using naval jelly to get rid of all the rust and followed that up with a liberal amount of Metal Ready (zinc phosphate). Doing five wheels takes a ton of time.....patience is key here.
Attachment 1522776
After that phosphate I went with self etching primer and high build primer to fill in the areas where the original wheels experienced some surface pitting due to rust.
Attachment 1522778
After the primer....a couple of coats of Silver base enamel (code BMW Polaris 60)....finished this off with a few coats of clear coat.
Attachment 1522780
I can't wait to see those new Pirelli CN36's mounted on these wheels.
Attachment 1522782
I also.... finally........... got around to installing the steering wheel.
I'm tackling the gas tank next and hope to get it done this week.
PSk and cucinando like this.
Jonathan
1974 GTV 2000 (ex-1992 Spider Veloce)
jthames is online now
post #1427 of 1592 (permalink) Old 10-29-2018, 03:46 PM
glynne jones's Avatar
I'm very impressed with your restoration, I am about to start work on mine
cucinando and BigMart like this.
glynne jones is offline
post #1428 of 1592 (permalink) Old 10-29-2018, 06:47 PM Thread Starter
1750GT's Avatar
First post! well welcome to this awesome Bulletin Board. The second post that you must now make has to be one documenting your restoration. I urge you to do so...I found that it will help to provide you with the much needed support and encouragement during those long stretches of challenging work....that will cause one to lose steam and momentum....believe me I've gone through a few of those during my resto. Those photos you just posted are ideal as the introduction in your thread. Go for it!
Notch likes this.
1750GT is offline
post #1429 of 1592 (permalink) Old 10-29-2018, 07:24 PM Thread Starter
1750GT's Avatar
Completion of the gas tank has stalled a bit...but I've come across some parts recently thanks to George Beston who kindly alerted me to a lot of NOS (early Spider parts mainly) that he is keenly interested in selling on behalf of a local long time Alfista. Some of these parts are common to the GTV. One part is this rear heat shield (original insulation and all)...
I just mounted it as (didn't want to disturb this too much for H + S reasons)....using the original screws that I of course replated.
Next were a pair of these Spica shock absorbers...
The Koni's I removed (put those back in the boxes to be used at a later date...or other project). I'm sure these are not the best performing shock..but I do want to keep as original as possible.
I do have one NOS rear Spica shock absorber as well....so will be keeping my eyes peeled for one more to complete the set. If anyone has one NOS that they'd be willing to part with...I am interested.
1750GT is offline
post #1430 of 1592 (permalink) Old 10-30-2018, 01:44 AM
BigMart's Avatar
Welcome aboard!
Looks like a great journey you are embarking on.
I second the request to document your resto - I have found it so useful to look at other peoples projects.
The value of other people’s experience and photos is immeasurable. I wouldn’t have started my project without that resource - and so I felt compelled to document my resto too.
It looks like are starting point of car condition is pretty similar.
1972 GT 1600 Junior
At the very start of a long restoration road....
BigMart is offline
post #1431 of 1592 (permalink) Old 11-03-2018, 06:44 AM Thread Starter
1750GT's Avatar
A few months earlier I completed refurbishment of the rear brake calipers....this past week was spent on the front calipers.The original condition of these was rather dismal and indicated maintenance by the previous owner was a little lacking...
After disassembly and some cleaning up they showed to be in rather good condition...
But I needed these to be in a little better condition. Being much larger in surface area than the rear calipers meant that my 5 AMP power source was inadequate to provide the necessary current for plating. After picking up a 10 AMP unit....I started up my plating kit....and voila. I was rather pleased on how these turned out.
With all the parts either new , replated...or even some painted....I was finally able to finish off the front brakes.
Installed on the car....thank goodness......some real progress for a change!...
1750GT is offline
post #1432 of 1592 (permalink) Old 11-03-2018, 07:57 AM
gigem75's Avatar
Very Nice! What did you use to position the pots in the calipers? I made a tool but wasn't 100% sure they were oriented correctly.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #1433 of 1592 (permalink) Old 11-03-2018, 09:05 AM
BigMart's Avatar
Lovely work
1972 GT 1600 Junior
BigMart is offline
post #1434 of 1592 (permalink) Old 11-03-2018, 10:03 AM Thread Starter
1750GT's Avatar
Oh that was very simple...I made an aluminum template from a diagram showing the correct orientation of the pots realative to the caliper.
1750GT is offline
post #1435 of 1592 (permalink) Old 12-02-2018, 12:14 PM
Nelspruit 105's Avatar
Location: High up in the mountains of Mpumalanga in South Africa
I have been following your restoration project from the day of your first post. The quality and your dedication to perfection is really inspiring especially over all these years.
I am a couple of years behind you on my current project and is going to start working on my rear panel soon. I was looking at the postings where you were battling with the boot lid (trunk) and the rear panel. My question how did you transfer the shape to the profiles gauges that you used to check the correctness of the panels. Did you use a Profile gauge?
Highly appreciated in advance
Nelspruit 105 is offline
post #1436 of 1592 (permalink) Old 12-02-2018, 08:13 PM Thread Starter
1750GT's Avatar
Originally Posted by Nelspruit 105 View Post
....I was looking at the postings where you were battling with the boot lid (trunk) and the rear panel. My question how did you transfer the shape to the profiles gauges that you used to check the correctness of the panels. Did you use a Profile gauge?
Thank you for the nice words and I'm glad the posts and photos are inspiring you to forge ahead with your project. The templates I made were traced directly from the trunk lid itself onto cardstock paper first then onto 1/8" thick MDF fiber board. It took a few trial and error attempts to get the cardstock templates correct....but yes a profile gauge would have been much faster and easier to do and will be a tool that I will acquire on my next project for sure. I'm going to look for at least a 2 foot or 3 foot long profile gauge if available.
braino likes this.
1750GT is offline
post #1437 of 1592 (permalink) Old 12-04-2018, 09:57 AM
An impressive restoration, congratulation !
lenul is offline
post #1438 of 1592 (permalink) Old 12-11-2018, 03:40 PM
fantastic build ,,so many tips one picks up ,i love your electroplating ,,must look into it ,,thank you
mac mclaren is offline
post #1439 of 1592 (permalink) Old 12-11-2018, 06:53 PM Thread Starter
1750GT's Avatar
Thank you....my objective on this resto was to do all of the work...mainly to challenge myself. There were some items that I sent out (like alternator rebuild) only to be disappointed with the poor level of workmanship. These little losses helped to solidify my objective even more.
I've had good success with the Caswell system.....with only a few poor results due mainly to me cutting corners during cleaning of the parts.Thorough cleaning and preparation of the parts by glass bead blasting is the key....a blast cabinet is a must! I would not venture into this process if you don't have one.
1750GT is offline
post #1440 of 1592 (permalink) Old 12-11-2018, 07:06 PM
Nakagtv's Avatar
Thumbs up
Hello Rossano,
Looks like you keep moving ahead at a steady pace, everything you touch looks amazing. Have I missed your wiper mechanism restoration part or not there yet? Did you find the source of those rubber caps or should I try to finish that little project?
Got one little complain to make, if I may Sir?
Even though your detailed posts of the process is very valuable to us and we enjoy reading them very much, could you please post bit more pics? You know how it goes: 1750GT's pics are worth...
Great work as always
Zaza
Current Alfas:
2018 Stelvio Ti Sport
1987 Milano Verde
1970 Euro-spec GTV 1750
Refreshing 1750 GTV
Nakagtv is offline
